Backspacing
Ok guys i have searched... but still unclear.... i want to run 22's on the truck 22x8.5 and 22x10.... its already lowered, by how much Idk it came like that when i got it.... what will i need as far as backspacing....
Here is a pic of the truck for some of you guys that have the eye maybe you can tell me how long it is what I can say is when I looked under the truck it still has the OEM spring what's look like it was cut and they put spaces in it I believe they cut it too low so I have to replace those the rear is on blocks hope that helps |
Re: Backspacing
Here is the truck sitting on 15's
Re: Backspacing
5.25"bs front.
5"bs rear.
Re: Backspacing
