Weatherstripping adhesive for drip rails?
I'm about to install some salvaged drip rails I got from the pick and pull. I'm wondering if it's okay to use 3M weatherstrip adhesive in between the body and the drip rail? Most drip rails I've removed seem to have a black sticky adhesive between it and the body of the truck. Will it suffice?
Re: Weatherstripping adhesive for drip rails?
That's what I used, I also put silicone around the holes I drilled so water doesn't come in.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
I used 3m 2-sided emblem tape. I found a roll that matched the width. Also sealant on the screws.
-400/400 1979 K25 350/SM465/205/44HD/14FF 1985 K20 400/400/208/10/14 1987 V10 TBI350/700R4/208/10/10 '85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968 |
What 400 said use a 3m 2sided body tape.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
The tape is a good idea. I am installing drip rails right now and I drilled the mount holes bigger and used nutserts and stainless button head screws in mine to keep the screws from dripping ugly rust.
