Old 09-08-2016, 07:23 PM   #1
sharkskinman
Bolt size exhaust manifold to pipe???
Apparently is I was rolling into the garage to fix my brakes one of the bolts that holds my exhaust manifold to the exhaust pipe flange fell out somewhere I need to know what the thread size and such as for that bolt so I can just go pick up two of them instead of taking out 1 to check the size
sharkskinman is offline   Reply With Quote
Old 09-08-2016, 08:14 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Bolt size exhaust manifold to pipe???
http://67-72chevytrucks.com/vboard/s...d.php?t=391778
Not knowing what engine.
http://www.oreillyauto.com/site/c/se...0598/C0112.oap
Old 09-09-2016, 10:10 AM   #3
sharkskinman
I6 250
Old 09-11-2016, 12:28 AM   #4
sharkskinman
Neither of those tell me the actual bolt that goes through the plans into the exhaust manifold from the pipe
Old 09-11-2016, 10:46 AM   #5
cru_zn_29
cru_zn_29's Avatar
If you are learning to work on your own truck you need to learn bolt sizes it will save you a lot of time and money and wasted trips buying the wrong size.(Take a sample)
cru_zn_29 is offline   Reply With Quote
Old 09-11-2016, 11:07 AM   #6
TopFuel1966
TopFuel1966's Avatar
Put a 9/16 wrench on one of the existing boltheads. If the wrench fits the thread size is most likely 3/8 - 16. The next smaller size would be 5/16 - 18.
TopFuel1966 is offline   Reply With Quote
Old 09-11-2016, 01:05 PM   #7
sharkskinman
I'm not Learning ****..
Just wanted a simple answer so I don't have to remove the other one to size it not links to threads that don't tell me
Thank u topfuel1966 simple and to the point , it's a 9/16 head so I'm off to the hardware store
Old 09-12-2016, 05:20 PM   #8
sharkskinman
Grabbed a couple 3/8s. They are too big
Although the original bolts that were in it are 9/16 head they must be the ladder of the 2
Going to hardware store anyways so going to pick some up
Can use the ones I got for something else
