Not too old to learn
After all these years finally....
Bought the truck 15 years ago. Finished and on the road, having fun
then the brake pedal return spring snaps....where do I find a replacement. Nearest thing I find is LMC but they show a clutch pedal return spring. Are they the same size? My truck is auto with vacuum power assist.
1968 C10 a way to long restoration. |
Re: After all these years finally....
Here is what I stared with.15 years ago.
![]() Join Date: Jan 2007
very nice truck. what all did you do to it?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Clutch pedal return spring is WAY bigger. Either your local salvage yard or hardware store.
Moderator
![]() Join Date: May 2007
Lookin good, hope to see it cruising around town sometime
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
First thing done, was remove the old worn out engine and trans, replace with a new 290 hp Crate and rebuilt T400 trans.Holley and Edlbrook intake.
Pulled cab and bed painted, alongwith frame. Rebuilt front suspension. Replaced old power assit drag like sysem to later power steering box. Rebuilt brakes and drive shafts New glass rubber gaskets etc Reupholstered seat/door panels Installed Old Air & cut out original location vents New wood bed. Southern Yellow pine. Most bright work replaced or cleaned up. It is my daily driver.
Daily driver. Not a work truck I'm retired.
Can be seen on streets of Riverside. Sent you PM.
8Door - I have a complete brake pedal assembly for an auto transmission setup that I swapped out for a brake & clutch assembly in my 72 Blazer. I believe it still has the spring on it. Not sure if this assembly is the same as the one in your earlier truck, but I would send you the spring if you are interested. Shoot me a PM.
#9 | |
