Junior Member
![]() Join Date: Jul 2016
Paint color
Is there anything on here that states the original paint color?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Paint color
The numbers that are stamped in the paint code box do not look like a normal paint code to me. Someone else may have a better idea.
Junior Member
Re: Paint color
Yeah, I can't find anything on those numbers either.
Thanks for the reply! |
Re: Paint color
Looks like it might have been a special order paint color as described here --> http://chevellestuff.net/qd/paintinfo2.htm
If that's the case, the info in that link suggests that those numbers should directly correspond to a DuPont mixing formula. So I'd recommend checking with a local supplier that sells DuPont (now Axalta) brand paint ... they should be able to look up & decipher those numbers. |
Just a car guy
Re: Paint color
LAst truck I had with weird numbers on the tag was a 69 government fleet truck. Mine was for the Air Force. It had all kinds of codes that could not be deciphered here. Perhaps that is what you have as well.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
