Old 09-09-2016, 12:31 PM   #1
CCCC
CCCC's Avatar
Connect/adjust Quadrejet electric choke - need info/advice
Just changed to the later model electric choke version of the Quadrajet (Edel 1904) - never had an electric choke - and need some overview info.
1. I assume that the "electric" aspect serves to close the choke plate and that a heat source from within causes the adjustable spring to open the plate as the engine warms up. (If the choke operation - closing and opening - is all electric, please straighten me out here).
2. Intend to provide 12v to the choke mechanism from coil connection (or similar) but see only one connector on the choke and assume that to be the positive. What need one do for a ground?
3. No doubt the choke spring/opening aspect will need to be adjusted to this engine - and am assuming that should be done with engine at op temp, but could be wrong. What is best procedure?
if you want to save typing and cite a good post/source, that will be fine.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 09-09-2016, 12:40 PM   #2
truckster
truckster's Avatar
Re: Connect/adjust Quadrejet electric choke - need info/advice
The electric choke is heated by the 12v supply, opening the spring on the choke. It's grounded through the body of the carb - you shouldn't need an additional ground. To adjust, just make sure it's closed when cold and open once the engine warms up. If it's never been rebuilt the choke probably has rivets and you won't be able to adjust it.
truckster is offline   Reply With Quote
Old 09-09-2016, 02:39 PM   #3
CCCC
CCCC's Avatar
Thanks for dispelling some poor assumptions and the concise info. Should be able to take it from here.
CCCC
Old 09-09-2016, 02:41 PM   #4
davepl
davepl's Avatar
Might sound odd, but if possible I like to power mine through a relay that is only on when the oil pressure sender (if you have an electric one) shows pressure. That way if you turn the key on and the engine isn't actually running it doesn't heat the choke.
A small touch, but one I've found handy.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
