09-09-2016, 12:40 PM | #1 |
Trans line to factory cooler direction
Which line is which, in and out, upper and lower on the radiator? I want to run an auxiliary cooler from the outlet of the radiator. I have a factory replacement radiator that cracked so I am changing it and adding the additional cooler while I there. Thanks.
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
09-09-2016, 12:47 PM | #2 |
Re: Trans line to factory cooler direction
Go here, pics should show you the way.
https://www.google.com/search?q=auto...HXGCCWMQsAQIcg
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
09-09-2016, 02:22 PM | #3 |
So the upper line and fitting on the radiator is out and the bottom is the feed?
09-09-2016, 02:23 PM | #4 |
You didn't say which transmission - it varies by model. You sig says TH400 so I guess that's a safe assumption, but just know they're not all the same - TH400 and 2004R are reversed, for example.
09-09-2016, 02:51 PM | #5 |
Yes, it's a turbo 400.
09-09-2016, 03:50 PM | #6 |
The lower fitting should be the coldest (outlet)
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
