Booster mounting
Does anyone know if booster brackets can be taken off and booster mounted directly to firewall without causing issues. I don't care for how far they stick out.
Re: Booster mounting
I don't really see why you couldn't if your bracket unbolts from the booster. Mine is riveted so no luck for me there. Besides, The bracket gives just enough room for the clutch master to get in there right beside it. Post pics if you do. Im sure it will help clean up the engine bay a little.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
I guess it depends on how it's made to be mounted. I've put mine directly to the firewall but that's how it is to be installed. hope this helps.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
Wow nice firewall. Thanks for help guys.
Go manual, no booster! I just switched to manual on my Chevelle and the MC cost me $9 shipped via warehouse deals. I can't give a straight up comparison because I went to discs in the front at the same time, but the pedal feel is pretty good and not as glitchy as power.
1968 LWB C20 / AC / Wood Bed |
Thanks everyone for the ideas. My truck had manual brakes and was scary to stop at times. Think I got it all figured out just going to run the system in my picture.
The bracket has a link system mounted in it. Chevy used the same hole in the brake pedal for both manual and power brakes. The linkage made the necessary difference in pedal/push rod ratio.
You can mount the booster directly to the firewall (you may need to drill holes), but you really need to address the pedal ratio. Drilling a new hole in the pedal is the normal way to do it. http://www.mpbrakes.com/ These guys have tech section with tons of important info.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
