Old 09-09-2016, 08:11 PM   #1
b00sted
b00sted's Avatar
One last window question
Would someone measure their 1 pc 49 era windows. I need the width at the bottom, the width of the top between the flat side and the break part and the length of the taper.
I need to order glass for my truck and with it being chopped I don't know how close a stock pc would be. My local shop is very expensive on uncut glass then expensive on cutting it.
If I can by stock and cut it down it sure would save some money.
Thanks for the help.
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 09-09-2016, 08:45 PM   #2
47 Fasttoys
47 Fasttoys's Avatar
Re: One last window question
Having glass cut for a chopped top by measurements alone is going to be a crap shoot. I've had some custom size glass cut in the past. I have had the best results by using a 1/4 inch Masonite sheet and make patterns, you can sand it by hand and cut it with a jig saw. A good glass shop should be able to go from your pattern to safety glass for well under $100 per piece. Mime was $40 per piece but that was 15 years ago.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 09-09-2016, 09:44 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
In your other post I didn't realize you were looking for chop top glass..that's a whole other thing then..I thought you were looking for stock window glass..like fasttoys says make a pattern..you might get away with a stock window glass that's cut down..does yours have the metal frame?.if so that will need modded also..
Old 09-09-2016, 11:59 PM   #4
mr48chev
mr48chev's Avatar
I'd do just as 47 Fasttoys suggested and go to Lowes or Home Depot and get a sheet of 1/4 inch Masonite and after cutting some patterns out of cardboard transfer the best one to the Masonite and cut and fit a pair of windows out of it and probably make an improved version on the second go.
I have to do the same thing on mine as it is chopped and stretched 9-1/4 inches though the doors. One of the local glass shop will cut glass to fit and then send it to be tempered and I am having it done that way.
My ongoing truck projects:
Old 09-10-2016, 02:32 AM   #5
MARTINSR
MARTINSR's Avatar
Absolutely! There is nothing to think about, you MUST make patterns and cut the glass from the patterns. That goes for all of them, if someone chopped it you have no idea how it was done. You must make patterns, it's easy peasy!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 09-11-2016, 06:54 AM   #6
b00sted
b00sted's Avatar
Got it guys.. All the other windows are done but the two side ones..They are 3/8 plexi now, very heavy and not even close to fitting...
Thanks for the heads up on the pattern making...
