Is a throttle on dash rare?
72 k10 custom deluxe...is a throttle on dash rare?
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
![]() Join Date: Nov 2003
Re: Is a throttle on dash rare?
Manual throttle is fairly rare. I think it was mainly used on trucks that had something driven by a PTO.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
It's not the most common option, as it's purpose was fairly limited. However, I have seen them before in junkyards and usually move past them.
![]() Join Date: Jul 2010
My 72 k20 has one. Not sure why doesn't have a pto. Just a basic pick up. I think maybe because it was a colorado truck and need to harm up sooner?
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
I guess most of the trucks that had them ended up wrecked.
When I worked on the drilling rigs in the '70's, I had a driller that had an early Blazer. He rigged up a hand throttle like those for cruising. One night, he took the eastern most Evanston (Wyoming) exit and tried to push it in and it wouldn't go. We took that exit at about 90 and he finally had to just shut off the key to kill the engine. We wouldn't let him use it with us in the car anymore after that. Dude wasn't called Crazy Dave for nuthin'!
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
![]() Join Date: Jan 2002
My dad had one on his 1972. We used it to feed livestock in the winter - 4 low, first gear, jump in the back to feed. The truck would creep along with a little throttle applied via the dash. I would say it was more common in states like Montana where I grew up for that specific purpose.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
![]() Join Date: Jun 2000
My '72 Blazer has one, and a '71 GMC I used to have had one.
The story I got when I bought the truck goes like this...
Truck was originally a Weyerhaeuser truck...the guy who drove it retired and Weyerhaeuser rebuilt the engine and tranny and gave him the truck as a retirement gift...as he wouldn't let them replace the truck with a new one for years...I bought it from him. The area I bought it gets to -30 in the winter so could be a cold weather option.
A farmer would use a throttle like that on a truck or tractor in the fields. The farmer could walk along the truck bed or a flat trailer and load or unload by himself. Even if he had a helper or two, they were more useful, helping with the loading. If there were plowed furrows, they never had to touch or correct the steering till they got to the end of the field.
'67 GMC 2500, 292, 4spd, AC |
![]() Join Date: Sep 2013
I could sure use that deluxe throttle knob!
My '70 Blazer has one, labeled on the spid, northwest coast truck, still have no clue why it's there. I do use it for warm up though.
![]() Join Date: Jun 2014
my 72 longhorn gmc has one it came out of Canada. I would say it was warming the truck up on cold mornings.
short bed are just cars without trunk lids trucks have long beds real trucks are longhorn ![]() 72 gmc 2500 longhorn 68 chevy c-30 50th anniv. 9ft step side 68 gmc crackerbox 8v71 detroit 72 gmc astro95 8v71 detroit |
#13 |
![]() Join Date: Oct 2009
yes rare. useful if you're doing some of the above-mentioned activities, PTO or not. Also handy for breakin in a new cam!
#14 |
Not to hijack thread - but what do you do with throttle knob when truck is fully warmed up and you just want to drive, say like in a truck without a dash throttle?
1971 GMC C2500 - 350 SB - 700R4 1972 Chevy C10 - 350 SB - TH350 |
#15 | |
![]() Join Date: Sep 2010
A Throttle work with the accelerator pedal to lock the throttle in a position to hold the rpm at a level that you want... My Dad used it as a "Cruise Control" on our truck... I am not sure it is all that rare and is found mostly on 3/4T and up...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
#16 |
Since the beginning, GM trucks and most others had throttle pulls. My 1942 had one, seen them in 50's trucks and so on. I assume it was mainly for warm ups, and by 1972 they had the automatic choke working well. Just my opinion
#17 |
My Dad's 68 3/4T with 292 6Cyl and 4 Speed manual (and no power anything) is the only one I have ever seen in person with the throttle. It also had the manual choke. So, it had (4) knobs with the headlights and wipers on the left with the throttle and choke on the right.
We used it to pick up hay bales in the summer for one person. Put it in 1st gear, set the throttle, get out, walk ahead and grab a bale, then throw it in on the way by. We also used it like to one other poster suggested, to climb in back and scoop out feed into the feed bunk while the truck idled along. Our truck was self-driving before self-driving was cool! My dad also used it in the field as a second tractor before we had a second tractor. He would pull the truck into the field with a tandem disc behind it, then use the tractor to set the hydraulics for the depth of the disc, then lock it in low, and make it go. I think he usually pulled it in second gear, low range 4WD. That truck would pull ANYTHING if it could get enough traction. I watched it sit and dig holes with the throttle set while he was trying to pull a tractor out.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
#18 | ||
"I ain't nobody, dork."
The farm I worked on as a kid had 2 trucks that had in dash throttles. Both 1972 GMC either C25's or C35's Dually's with flat beds. They were used in the hay fields. Both of them had the doors removed. A crew of 4 dudes would head out to the hay fields and when we started picking up bales, we'd shove the tranny into low gear and set the hand throttle at whatever pace we could pick up the bales at. No one in the drivers seat, and every so often someone would pull the steering wheel one way or the other to point it where we needed to go.
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#19 |
I added one to mine in anticipation of the air compressor and possibly the welder I plan to add.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#20 |
My truck has one too. It looks like it was mainly a farm option, which would make sense given the other options on my truck that make me think a farmer or big rig trucker ordered it: clearance lights, driveline parking brake, oil bath air cleaner, etc. On a 1/2 ton CST!
