09-09-2016, 10:16 PM | #1 |
What are these and what for?
One on front of each head. I'm pointing at one. Might win ignorant question of the day.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-09-2016, 11:51 PM | #2 |
Re: What are these and what for?
09-10-2016, 12:06 AM | #3 |
402. The heads came off a 396. Actually more better heads. 402 had smaller ports I hear, 8.5/1 Vs 10/1 compression if I remember right. Come to think of it, that MIGHT be the difference where there are 400 badges with 396 blocks.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-12-2016 at 11:19 PM. |
09-10-2016, 12:23 PM | #4 | |
09-10-2016, 12:25 PM | #5 |
Possibly ignorant question two days straight.
09-10-2016, 12:32 PM | #6 |
I assumed it was related to casting and not operation, but I honestly don't know. I broke a breaker bar trying to get one out once, so they don't yield easily...
09-10-2016, 12:39 PM | #7 |
cyl hd coolant drain pipe plug. comes in handy when removing a cyl head so you don't dump coolant into the cylinder upon removal when the mating surfaces separate.
09-10-2016, 12:42 PM | #8 |
Not ignorant at all, if you have the need to know then you ask a question and hope that someone comes up with the Correct answer. Have you tried chasing down the Casting Numbers and the Suffix code as well as the Heads Casting numbers this might just get you started in the right direction.
Show yourself your not a ignorant person by putting One Foot in Front of the Other. Life is a Journey so get to step'en. |
09-10-2016, 10:34 PM | #9 |
Very cool. Nice to have a name and function for things. Thank you, and all other replies.
09-10-2016, 11:26 PM | #10 |
You bet Tony. And there are no bad questions. We all kinda operate under the assumption that we've all come to this site at different times in our own learning curves. I sure wish this site was around when I was 16. Well, actually, would've been nice to even have a computer around too.. but, I'm dating myself. Some guys start this stuff at 65 and are starting from scratch because they've worked their whole lives to be able to retire and START tinkering and some guys are tinkering at 14 yrs old. I've learned a lot here. Imagine how boring it would be if we all knew everything here.
09-11-2016, 12:18 AM | #11 | |
It's mostly all new to me. I've never even done a brake job, and here I am tearing her down. Wasn't exactly raised around tools (father protestant musician, mother "Jewish princess")............but I've made them a habit for the second half of life +. Now if I can just figure out this wiring. Man, these schematics are hard to read. Looks like I'm at the Relay Assm. and Relay Assm. Delay on the front firewall.
09-11-2016, 12:27 AM | #12 |
Only an arrogant personality thinks a question can be "stupid" (or as it's been put here, "ignorant.")
09-11-2016, 01:07 PM | #13 |
While I don't doubt they -can- be used as a drain plug, I do have some doubts about that being their reason for existing. I'd still like to know the rationale for GM including them in early castings, and why they went away eventually...
09-11-2016, 07:46 PM | #14 |
I believe its just a galley plug.Removed when the head is rebuilt and machined to clean out the passages.
09-12-2016, 12:10 AM | #15 |
Post Whore
My understanding is that they are used to remove the casting sand during the manufacturing processes. They were to hook up hoses to and flush the sand out of the water passages
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-12-2016, 12:30 AM | #16 |
Pretty sure they call them "Pipe Plugs." They are NPT and can be used as an alternative for a temp coolant temp sensor. As far as also being used to remove casting sand, I guess they could be but not sure. I have heard you need serious heat, hardened tools, and a lot of muscle/leverage to get one out. Never tried myself.
1972 K-20 Custom Camper 1971 K2500 Custom Camper (Sold) 2014 GMC 2500HD DMAX |
09-12-2016, 11:16 PM | #17 |
This
09-13-2016, 01:00 PM | #18 |
I still think they were a foundry thing, not an automotive thing. Maybe they got better shaker tables to get the sand out and found they didn't need to use them anymore? Really wish I knew though.
09-13-2016, 01:32 PM | #19 |
My 1969 CST 396 with an October 68 block date has them as well.....I was wondering also but didn't ask.....
IT IS WHAT IT IS |
