Old 09-10-2016, 02:31 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
will these hubcabs work with my wheels?
as the title says Im hoping the hub cabs will work with these wheels. I dont know how they were originally mounted. Any idea or help is greatly appreciated!
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 09-10-2016, 04:54 PM   #2
obijuan
Re: will these hubcabs work with my wheels?
Not as is. With a little work likely. You will need the 3 bolts that hold the caps on and then you will need to drill and tap those wheels for the fasteners to affix the caps.
obijuan is offline   Reply With Quote
Old 09-10-2016, 05:28 PM   #3
Wildstreak
Wildstreak's Avatar
where they tapped? The previous set I had just had small sheet metal screw I found. Ill try drilling and taping if that doesnt work. I new I had to drill the rims just wast sure if the steel was thick enough for the caps to work with.
57 chevy 4x4
68 burb 2wd:
Old 09-10-2016, 09:04 PM   #4
71swb4x4
71swb4x4's Avatar
If they fit when mocking them up then I think you are good. You may even get by with a self-tapping screw, although a pilot hole wouldn't hurt anything as long as you don't go so big that the threads can't grab.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-10-2016, 09:50 PM   #5
dozerbill72
dozerbill72's Avatar
Yes they will but you will have to drill and tap the holes to bolt them on. I did the same thing on mine Blazer. It's not hard, just some careful lining up. Be careful when tapping the holes not to break the tap off they are very hard and don't drill out.
dozerbill72 is offline   Reply With Quote
Old 09-10-2016, 10:48 PM   #6
Yes, as explained. But those aren't hubcaps, they are called center caps.
