Old 09-10-2016, 02:33 PM   #1
BigDan3131
BigDan3131's Avatar
Question Hydraboost Question
Is there something unique about each version out there? I ordered two of them last night just to see what if any differences there are. I ordered one for a 1987 Chevy 1 ton truck and the other is the 93 Astro Van, I know with the Astro Van you need an adapter plate. I can order all factory style hoses thru work as well [O'Reilly].
Is one better than the other? Is there a model out there lighter in weight?
I'm sure CaptainFab will have an answer...
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-11-2016, 12:17 PM   #2
BigDan3131
BigDan3131's Avatar
Re: Hydraboost Question
Well, after looking at them side by side the only difference I can see is rod length and depth and diameter of the master cylinder end. Would I have to get the rod between them at a wrecking yard? I'll look in our vast array of resources for that too.
The prices before tax were $163 and $187
Old 09-12-2016, 12:40 PM   #3
bs46488
I did hydroboost using stock GM parts. I'd have to go flip through all my receipts to find out which actual parts I bought.
I used stock lines, I just had to figure out a way to get the metric line to my old power steering gear. All the rest was simple bolt in (and trial and error)
bs46488 is offline   Reply With Quote
