Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-10-2016, 04:22 PM   #1
gmachinz
Volvo dual speed fan relay kit
I've got (2) of these built at the moment-if you don't feel like building your own, here ya go! The 180/195 fan switch is BWD tfs651 and can be bought at any parts store for about $30-35. You'll also need a 14mm x 3/8npt adapter and crush washer. I keep those in stock also. If you want a kit minus the fan switch cost is $120 per kit. The relays are 70A Hella versions mounted in stackable bases designed specifically for the oversized relay terminals. Entire setup is protected by a sealed 630-series 40A fuse holder. As relay kits go, this is as stout as it gets! The BMW switch connector and pigtails are OEM BMW pigtails too! The yellow relay is the main IGN controlled load relay for the Volvo relay and the white relay is the AC override high speed relay. A color coded diagram is included and all leads are labeled.
Typical fans that can be controlled by this kit are:
Mercury Sable
Ford Tuarus
Ford Tbird
Mercury Cougar
Crown Victoria
Lincoln Continental
gmachinz is offline   Reply With Quote
