T5 reverse light switch
In the process of replacing the 3 ott with a T5 from an '89 Camaro, and an early 90's s10 tailshaft. The t5 is a world class unit. Anyways, not quite sure what to do about the reverse light switch. How do I go about wiring it up? It looks like there are 2 sensor type fitting on it. Thanks!
Re: T5 reverse light switch
You can order the wiring pigtail on line. One end plugs onto the transmission and the other end has the two wire leads that you splice to the original wiring that went the other transmission. I'll check my records and post back part# and more info...
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
I ordered mine at Ron Francis Wiring online. The # PG-094 fit my application on a '84 Camaro T5. Look at your connection to see which one will apply to yours. Hope this helps a little...Ed
Oh cool that's a lot easier than I thought. Thanks very much for taking the time to help me out! Will be looking up that part number.
