Old 09-10-2016, 09:51 PM   #1
General23cmp
Lowering springs or dropped spindles?
Is there a "right" answer to drop the front?
General23cmp is offline   Reply With Quote
Old 09-10-2016, 10:20 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Lowering springs or dropped spindles?
First we need to know how much you are looking for (the drop). 1",2", 3", 5" are all possible...
Old 09-10-2016, 10:25 PM   #3
General23cmp
I'm leaning toward 3" in the front.
Old 09-10-2016, 10:41 PM   #4
Warrens69GMC
for 3" I would go spindles. If you wanted lower in the future, you then can swap in lowered coils.
Old 09-10-2016, 10:45 PM   #5
General23cmp
Thanks. The 4" guys look cool, so that's possible.
Old 09-10-2016, 10:54 PM   #6
Boog
laying low
Boog's Avatar
Do your research as there are 2 1/2" spindles and 3" spindles. Wheel choice figures into the equation too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-10-2016, 11:21 PM   #7
General23cmp
Yep. I like my old school rally 15" wheels, but seems like you need to go bigger when you go lower.
Old 09-11-2016, 09:10 AM   #8
Mike C
Mike C's Avatar
You didn't say what year truck you had. If you have a drum brake truck then spindles aren't available unless you are converting to disc.
IMO, if you have a drum truck you SHOULD be converting to disc...
Spindles have no effect on ride, alignment (shouldn't at least...) spring rate, travel, etc. So, my opinion again, is that is the BETTER way to lower. But most guys want more than 2 1/2" when they drop so you do both. 2" springs have minimal effect on all of the above.
My truck is dropped with ECE 2 1/2" spindles and 2" springs so I did put my money where my mouth is.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-11-2016, 10:45 AM   #9
General23cmp
Mine is 72 discs. Thanks.
