Where can I find T Bolts to mount west coast mirrors?
I bought some delbar swing lock mirrors but they didn't come with the mounting bolt and acorn nut. Where can I buy these, or what did you do as an alternative? Do they have a name other than t bolt?
Looks something like this. It is used in the door above the window from inside. It spreads out the clamping force. On the outside the mirror is held on by an acorn nut. ![]()
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. |
![]() Join Date: Aug 2008
Re: Where can I find T Bolts to mount west coast mirrors?
Unless you can find some used, I believe you will need to modifing an existing fastener. Maybe grinding flat one side of a button socket cap screw?
I've found reference to two OEM part numbers, one for Ford (383100-S40) and one for GM (D0HZ-17386-A). Unfortunately I can't find them anywhere.
I don't have a grinding wheel otherwise I might just buy a carriage bolt or something and grind it down.
Found these on Amazon
https://www.amazon.com/WoodRiver-T-B...eywords=t-bolt |
What thread size we talking about? what is shown above are toilet bolts in brass you can get them at Home Depot in 1/4-20 or 5/16-18 you can get them in stainless steel https://www.amazon.com/Stainless-Ste.../dp/B00D6ONYR8
#6 | |
At home depot go to toilet repair parts .....you are looking for the bolts that mount a toilet to the floor flange watch as they do have both 1/4 and 5/16
Local home depot and Ace both did not carry stainless toilet bolts. Gonna order some t-bolts I found online from a mfg named Rockler.
Here's what I ordered on amazon. http://amzn.to/2cPcEhc I'm not sure if I'll have access to the back side of the bottom mounting location, but just in case, I got extra because I'd rather use these with acorn caps than sheet metal screws.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. Last edited by Praxiss454; 09-11-2016 at 10:33 PM. |
