Steering column year?
Can anyone help me narrow down what year this column is? I'd like to find out so I can go ahead an swap the wiring around if need be. I bought it from guy that has a small personal yard, it was just laying loose in a truck so he was unsure of the exact year. If I need more/better pictures of a specific area to help narrow it down let me know.
Thanks! ![]()
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
Re: Steering column year?
I could be wrong. But a column is a column. You may have to repin the harness but they should be I interchangeable
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
For sure it's older than 84--that was when they put the wiper controls on the turn signal stalk.
Moderator
![]() Join Date: Oct 2008
It has the long harmonica plug so it's between 1978 & 1983.
The small Hazard lamp button places it closer to 1978. If you have the smaller harmonica plug from your original 73-77 column you can put it in one of those too. I believe there were several plugs used in those years so...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#5 | |
Hopefully it is a 78+ and in that case it should just plug right up, everything I've read so far says everything 78-83 is a direct swap wiring wise.
It's pretty easy to pull the wiring harness out and swap it over if they don't just plug right in. I put a tilt column in my truck and the plug was different so I pulled it apart and swapped it around.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
![]() Join Date: Jun 2009
Is the output shaft splined or does it have a double D?
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
It's splines
It is 77 and earlier
But the column in my truck is also splined at the bottom as well which just adds to the comfusion. I guess all I can do is compare the wiring plugs when I pull the current one out.
It may be 78 and earlier that is splined then. I tend to disagree on the plug years as well. I rebuild a lot of columns and I have seen that it is 75 and earlier with the shorter plug. I actually have a very hard time coming up with the shorter plug when I buy new switches for my customers that have 75 and earlier trucks. I usually repin them with the customers plug if it is good and not broken.
Moderator
I had a short plug in the 76. Whether it was original is a guess. I am the 5th owner.
I was told that 77 and before were a see what you have and re-pin to fit if required. The best advice is to hang onto the original column til the new one is installed and working 100%. Spline vs Double D is a matter of changing the intermediate shaft. I thought about adding tilt and moving the dimmer and wipers to the column using a 1985 -1994 CK RV or T400 column. Not sure how many mods to the column itself would be required to fit an early T400 column but I was looking that direction before I lucked into the 1979 unit I put in my 76.
And please let us know if and how your repairs were successful. Last edited by hatzie; 09-15-2016 at 01:50 PM. |
#13 |
Well the LMC catalog gives me these tid bits of info.
Ignition switch fits 73-87 one part number for it Ignition Lock Cylinder is 73-77, then 78 (3 numbers for 78 only) and then 79-87 Turn signal switch 73-76, 77-83 and 84-87. So with the info you gentleman have provided, plus that I'm going to guess this is a 77-79 column. I am going to try and pull the wheel off tonight and see what the lock cylinder looks like as that should narrow it down more. But with all the info I have now I think I'm pretty safe on the wiring side and shouldnt have any issues. As mentioned I will still compare them when the current column is pulled for the swap. I'll update with what I find. On a side note anyone know a place or part number for decent priced turn signal and tilt levers? I cant see paying $50 for two levers....
#14 |
So I got it apart, an I think it has a mismatch of parts.
This is a lock cylinder that should be retained by a screw correct? ![]() But this is a housing for a cylinder that wouldn't have a retaining screw. Based mainly off the fact that there obviously isn't a screw to hold the cylinder in. ![]() Leads me to believe this is probably a 78 column an someone picked the wrong cylinder for at when it was replaced at some point, since both type cylinders are listed under a 78 it's a 50/50 shot if you don't know.....
