Old 10-07-2003, 12:06 PM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
Need pics of 3/5 drop.
I plan to one day install bags in my project, but for now am going to install 3" dropped spindles, and some 5" springs in the back. That way once I can afford the bags, I will leave in the dropped spindles, and only have to get rid of the dropped springs in the rear. ('81 front suspension)
So does anyone have any pics of a 3/5 drop to give me some ideas? I hope to also run 18/20" or 18/18" rims on the truck.
Thanks!
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 10-07-2003, 12:18 PM   #2
paintpyro
paintpyro's Avatar
Here is a 3 inch spring of front, 5 inch drop in the rear. Itll probably settle a little more in the front with sheetmetal and the springs seating after a few miles. I should have the sheetmetal back on by the weekend.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 10-07-2003, 05:11 PM   #3
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
paintpyro, did you do any other mods to the rear besides the drop springs?
-Ron-
OldSkool71 is offline   Reply With Quote
Old 10-07-2003, 07:23 PM   #4
paintpyro
paintpyro's Avatar
Oldskool. I'm running 4 inch springs and a 1 inch drop block. I also have an adjustable track bar and shock relocation kit from Classic Performance.
"Schleprock"
350 w/TH400
rallys and BFGs
Old 10-07-2003, 07:51 PM   #5
crazy longhorn
Fabricate till you "puke"
3/5, + 1 1/2" body drop.... http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-10-2003, 12:33 AM   #6
wdz28ss
wdz28ss's Avatar
roughly a 5/6 or so. who knows..truck was like this when i got it a while back. no spindles...just coils front and rear
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had"
wdz28ss is offline   Reply With Quote
Old 10-10-2003, 11:16 AM   #7
race-n-jason
-Praise the Lowered-
race-n-jason's Avatar
3" front springs 5" rear springs............
Race-N-Jason
('71 Chevy C-10 LWB 454/TH350)
('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual)
race-n-jason is offline   Reply With Quote
Old 10-10-2003, 11:46 AM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Did that require a c-notch? If not, does the anything hit on bumps? I keep hearing conflicting stories about 5 inches in the rear.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 10-10-2003, 12:28 PM   #9
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Yeah, I was wondering the same thing. Also did you do any other changes in the rear such as adjustable panhard, shock mount relocation, ect. What size are your rimz and tires? And how does it ride?
thanks
-Ron-
Old 10-10-2003, 01:59 PM   #10
Super Chevy
Super Chevy's Avatar
paint-pyro from this angle it looks like that VW is sitting on so big rims, just woundering
S-C
Super Chevy is offline   Reply With Quote
Old 10-10-2003, 02:02 PM   #11
race-n-jason
I would probably recommend a C-notch kit if you plan on hauling anything, however I did not install one. The rearend does hit the bumpstops from time to time, if the air in the shocks is low. It would probably rest on the bump stops if there were a load.
I didn't notice any real need to add an adjustable panhard bar. My rearend is centered just fine. However i didn't put a micrometer to it (LOL).
With no load it rides pretty good. If i get the chance some day I will use the shock relocation kit, and the C-notches to make it right.
The wheels and tires are as follows:
front 15 x 8 with 215/70's
rear 15 x 10 with 275/60's
Race-N-Jason
Old 10-10-2003, 02:19 PM   #12
paintpyro
paintpyro's Avatar
S-C, the backs wheels are 15x8, with a tall back tire. I was borrowing it from a buddy and have given it back now. I'll admit though, it was fun to drive . My daughters liked ridin in the back seat. With the lightweight baja kit and full synchro trans, pitchin it around the corners was commonplace. The mileage sure didnt suck either.
Ive got Doetsch Tech drop shocks, along with the track bar and shock relocators, no c-notch. That'll come later.
"Schleprock"
350 w/TH400
rallys and BFGs
