Old 09-12-2016, 10:09 PM   #1
mehoff400
alternator alignment
my alternator alignment has been off from day 1 i bought my truck. is there a way to fix it?
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 09-12-2016, 10:50 PM   #2
bpmcgee
bpmcgee's Avatar
Re: alternator alignment
Put a washer on the bolts between the bracket and the block?
bpmcgee is offline   Reply With Quote
Old 09-12-2016, 11:02 PM   #3
vince1
If you give us another pic with the alternator folded down with the belt off and top bolt out we might offer suggestions.
It might be a good time to upgrade and get one with a different mounting configuration.
vince1 is offline   Reply With Quote
Old 09-12-2016, 11:03 PM   #4
LVPhotos
LVPhotos's Avatar
Think the bracket is on wrong side of altanator ear or is bent. Belt probably too short so po opted to flip sides.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-12-2016, 11:10 PM   #5
Praxiss454
Praxiss454's Avatar
Check out my thread on a similar topic, not sure if that's the same as your issue but appears to be.
http://67-72chevytrucks.com/vboard/s...d.php?t=716219
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 09-13-2016, 12:06 AM   #6
Captainfab
60-66 Nut
I would elongate the bolt holes in the lower bracket where it bolts to the block and slide it forward.
Old 09-13-2016, 12:10 AM   #7
62stepside longbox
62stepside longbox's Avatar
That is exactly what I did when I replaced my generator with an alternator
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 09-13-2016, 02:02 AM   #8
jtrichard
You could use something like this
http://www.ebay.com/itm/1964-67-PULL...pXWIcB&vxp=mtr
this one looks to be in better shape
http://www.ebay.com/itm/OEM-Alternat...tXzcoa&vxp=mtr
new one
http://www.ebay.com/itm/Powermaster-...NXwiZ9&vxp=mtr
jtrichard is offline   Reply With Quote
Old 09-13-2016, 05:50 PM   #9
mehoff400
i'm not seeing what you did to fix the problem.
My truck
Old 09-13-2016, 07:31 PM   #10
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The bottom bolt will need some spacing too.. I agree this bracket is on the wrong side of the ear.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-13-2016, 07:46 PM   #11
60-66
60-66's Avatar
Looks like someone swapped in a new alternator from a car application. The only difference is the pulley on the alternator , you have the wrong one. You need the correct truck one that extends out further. Notice how the one pictured below is spaced out about a half inch , this is a heavier one piece pulley on a bone stock 1965 Chevy truck six. I would also correct that bolt on the top of the alternator to the adjusting bracket.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-13-2016, 07:59 PM   #12
60-66
60-66's Avatar
I can also add, the correct GM part number is 1958095 .
Old 09-13-2016, 09:32 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
GM straight 6's used a 6 cylinder only alternator pulley. Rather than do a ton of mods it's best to find the right pulley. My 66's 292 had the alternator swapped out at some point and was setup like yours with the belt way off. I left it that way for years with no problems. haha But I did find a spacer pulley and put it on.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-14-2016, 11:47 AM   #14
Brad54
Brad54's Avatar
One thing I've run across on small block Chevy's, and a high-end shop had the same problem with a big-block Mopar: The high-end shop bolted the water pump housing to a Bridgeport and took material off.
After studying it on my SBC a while, I realized that the company that rebuilt or manufactured the water pump hadn't pressed the pulley flange on far enough.
Take a piece of wood, lay it in the grooves and check the alignment of the crank pulley and alternator pulley.
Then check the alternator and water pump, then check the crank and water pump.
If you find the crank and alternator line up, the water pump pulley flange is the problem.
Take the back cover of the pump off, support the shaft, and press (or pull) the pulley's mounting flange until it is in the right spot.
Make a new gasket for the back of the water pump, and go merrily on your way.
If it turns out to be the alternator is in the wrong spot, you've got to shim the bracket to the right location, or find one with the right bends in it.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-14-2016, 09:56 PM   #15
Praxiss454
Praxiss454's Avatar
I took off my pulley and put some metal washers in as spacers, and that helped a bit. I'm not satisfied w/ the results though. If you have the means to modify your bracket I bet what these guys suggest would work, I just haven't tried that yet.
Old 09-15-2016, 02:01 PM   #16
TJ's Chevy
TJ's Chevy's Avatar
Here is another example of a 6 cylinder pulley. This is the stock one from my 64's 292 transferred to a new alternator.
Old 09-15-2016, 02:08 PM   #17
padresag
it doesn't seem aligned properly either
ron
padresag is offline   Reply With Quote
Old 09-15-2016, 03:03 PM   #18
TJ's Chevy
TJ's Chevy's Avatar
ron
More the camera angle than anything. It is a hair short, but that is how it was from factory.
Old 09-15-2016, 06:34 PM   #19
T and S
T and S's Avatar
You have plenty of threads on your pulley. Go to a good alternator rebuild shop, they have spacers in different thicknesses that will space your pulley out to align it up. Takes about 2 seconds to buzz off the nut and put the spacer / shim behind it. That's what I did, heck they didn't even charge me for it.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
