09-12-2016, 10:48 PM | #1 |
Well, my rear end is toast
On this other 66. I am about to push this thing into the street and move on. I pulled the axles to install the 5 lug CPP axles I bought. Someone, along the line, had "rebuilt" the rear end but removed the factory Posi and installed a beat up "Open" carrier and best of all? They used 63-64 guts with 17 spline axles and spiders. I also noticed the mounting pads where the u-bolts fit through, 1 of the holes is wollowed out really bad. I cannot find a rear end in Austin area that I can afford at all. This project is dead to me.
My mother is a recent cancer survivor and this truck build is for her |
09-12-2016, 11:09 PM | #2 |
Re: Well, my rear end is toast
Been there and felt the same. Felt like selling several times. Let it sit and take a break. Keep searching craigslist and a deal will pop up, promise.
Posted via Mobile Device |
09-12-2016, 11:14 PM | #3 |
You can buy new saddles for a decent price from many vendors. (Capt. Fab makes them I think.) Then you can use a non-stock rear that you may find for a better price.
09-12-2016, 11:39 PM | #4 |
I thought about a different rear but I already have aftermarket wheels and cant go any wider than the stock rear width. Plus I've already installed all new brake lines, brake rebuild kit etc. other than that, the truck runs great and I've done a TON of work to it already. It's just sitting now and I hate walking by it every day sitting with the rear on jack stands.
09-13-2016, 12:14 AM | #5 |
60-66 Nut
A '63 to early '70 truck 12 bolt will be the same width. A late '70 to '82 12 bolt will be 1.5" wider overall, but you can use parts from one (such as the carrier) if you happen to find a deal on one in that year range.
09-13-2016, 06:39 AM | #6 |
All you need is the guts from a 30 spline carrier. Look in the junk yard for a 73 to 82 with a 12 bolt as they are everywhere it seems.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-13-2016, 11:47 AM | #7 |
Post Whore
Good things take time my friend. Don't worry, something will pop up.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-13-2016, 12:57 PM | #8 |
I just replaced my posi, if you call Adams Driveline in Henderson, NV (702) 568-5680 and see if they held onto my old parts.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
