Old 09-12-2016, 11:12 PM   #1
Aus69c20
Aus69c20's Avatar
Cab gutter sealer
Hi everyone.
I've done a bit of a forum search and can't come up with anything specific to my situation.
My issue is the cab gutter sealant has a few cracks and breaks in it which the Po had put some silicone over. I'm wanting to fix the problem a little better but not wanting to repaint the roof. Just wondering what my options are?
Should I bite the bullet and strip the old sealant, cleanout and prime the gutter, seam seal and spray it white hoping I can minimise damage to the existing roof paint.
Or can I scuff what's there and go over the top with new sealer.
Or repair the problem areas with some white seam sealer and call it good.
I would be using a rattle can to paint if I had to paint and whatever l do I'm hoping it will last 10 yrs or so when a resto is on the cards. The truck will also be close to a daily driver, rain or hail.
Here's a picture of the worst area. Thanks in advance
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 09-12-2016, 11:29 PM   #2
Gmc.guy
Gmc.guy's Avatar
Re: Cab gutter sealer
I haven't done it on a roof gutter but i have on other daily drivers, stick a double or triple wide layer of masking tape up to the edge of the sealer you want to remove and cover the good paint. Then put a single layer of cheap duct tape just up from the edge to protect from dings. Then you can pick , chisel , the bigger chunks out and use something like a little brass wire brush to clean it out smooth. I've used the stiffer brass brushes in seam dealers before and they work well. Slip into a drill and go. Then rattle can and seam seal new. Just don't leave the tape on too long if it takes you a while. It's way easier to take the tape off and put back on than clean the stickies off
-Cody
Gmc.guy is offline   Reply With Quote
Old 09-12-2016, 11:30 PM   #3
Gmc.guy
Gmc.guy's Avatar
In ten years the body work will be much easier if you clean out and seal it rather than spot repair and end up with pinholes.
-Cody
Old 09-13-2016, 07:09 AM   #4
Aus69c20
Aus69c20's Avatar
Thanks Gmc.guy, sounds like good advice.
John
Old 09-13-2016, 08:33 AM   #5
custom10nut
custom10nut's Avatar
Good thread, because I'm about to do the same thing. Anybody have suggestions on quality sealers? And would the local auto parts store have it?
custom10nut is offline   Reply With Quote
Old 09-13-2016, 08:39 AM   #6
webfoot
Flexible non-hardening seam sealer of your choice. Here are several products:
https://www.semproducts.com/repair-seam-sealers
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 09-13-2016, 08:56 AM   #7
Dad's72
Dad's72's Avatar
Your worst area is better than my best.
Dad's72 is offline   Reply With Quote
Old 09-13-2016, 10:19 AM   #8
LongBox
Yeah, I was just gonna say that the gutters are in pretty good shape for an old truck.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 09-13-2016, 11:51 AM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
There's sealant in the gutter?
My truck has almost none left, so I'll be doing the entire drip rail around the cab.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-13-2016, 06:07 PM   #10
Aus69c20
Aus69c20's Avatar
Thanks everybody for your input.
It sounds as though mines not to bad at all compared to some. I've got a good solid truck and im doing what I can to keep it that way so I think I'll follow gmc.guys advice.
Thanks again
John
Old 09-13-2016, 06:27 PM   #11
ss454conv
I will re-enforce the importance of properly sealing the drip rail. When they leak, the damage to the inner structure is worse than most can imagine. A leaking drip rail is essentially the death of most cabs that get replaced. Yours does look pretty good but don't cut a corner here. Plenty of good advise above. I will add that I would completely dig out the original sealer all the way to metal. Be sure that you removal all rust then epoxy prime, seam seal, and then top coat. You can get a good quality epoxy primer and paint in an aerosol can from most paint distributors, so no paint gun needed for a small preservation job like this.
Good luck.
ss454conv is offline   Reply With Quote
Old 09-13-2016, 07:20 PM   #12
Aus69c20
Aus69c20's Avatar
Thanks ss454
John
