09-12-2016, 11:23 PM | #1 |
Dome Light
OK. I give up. How do you run a wire to the dome light on a 55 Big Window. I can't seem to find a path to route a wire through the B-pillar. Seems to be drop only to about the level of the bottom of the glass. Can't see in there, can't feel in there. Ugh. Old wire is gone so I can't pull one with it. Hoping I don't have to resort to a clapper.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and 47RH AOD transmission http://67-72chevytrucks.com/vboard/s...d.php?t=640042 |
09-13-2016, 11:19 AM | #2 | |
Hollister Road Co.
Re: Dome Light
There is so much sheet metal with dead ends in it through that paths that its almost impossible to do it. I honestly think they did it with the roof off. I learned the hard way that you never pull the old dome wire out unless you have a replacement wire or a wire pull attached to it. I've have run the wire from the light down the corner cab panel to the floor and over to the dash. If you use SXL grade wire it won't rub through, GPT wire will rub through under the floor mat |
09-13-2016, 12:45 PM | #3 |
Re: Dome Light
i think the clapper would just flash on and off in our old noisy trucks
i used a flat plastic packaging strip to run up thru the A-pillar, plastic strip like a package comes with not sure you can get anything thru the B-pillar you'll need to try a couple different ways: up and down; bending the end a bit to make a different path each time eventually it will go thru (about time all of your hair falls out)
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-13-2016, 04:21 PM | #4 |
Re: Dome Light
Some one use a heavy string or twine and blew it thru with air hose, search box above might show the thread.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
09-20-2016, 07:54 PM | #5 |
Re: Dome Light
I used a piece of wire to feed the new wires through but my headliner was out and it wasn't real bad
09-20-2016, 09:14 PM | #6 |
Re: Dome Light
I used .030" MIG welder wire. I removed the large plastic covers from the wire terminals and taped the terminals together so they wouldn't snag.
09-22-2016, 09:13 AM | #7 |
Re: Dome Light
dental floss and a vacuum,them pull bigger string
09-24-2016, 09:11 PM | #8 |
Re: Dome Light
I've used a plumber's fishtape:
https://www.google.com/#q=fishtape ...and compressed air and a string. I have my equalizer, radio and DVD player in a pod above the rear view mirror -- in addition to the dome light and lighted sun visor mirrors, so I have some serious wiring up there (including coax for the speakers).
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
09-28-2016, 10:41 PM | #9 |
Re: Dome Light
factory wire goes around the headliner then down the A pillar..
