72 chevy
Hey fellows, I have a 72 Chevy c10 pick up.
i have installed an electric cylinder to lift bed And want to install gas tank in rear under bed. Also want to run my fill tube close to cab , I did not want To cut fender or inside of bed to fill tank. A tank with A 90 degree turned toward driver side may work. I would appreciate And ideas on this. |
Re: 72 chevy
I have seen a gas fill nozzle under the left rear fender on situations like this. The truck had a dump bed and it was on the front side, under the wheel well.
It would be wise to create a bit of a weather shield to help prevent contamination into the fill nozzle during inclement weather.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
Re: 72 chevy
Thanks , this is helpful, I have to find a tank
That will work. |
