Old 09-13-2016, 01:47 PM   #1
Texas60c10
4 speed transmission crossmember
Need help..swapping out a 235 with 3 on the tree to a SBC 350 with 4 on the floor with a Saginaw transmission in my 1960 c10. What crossmember am I going to need to use for the 4speed?
Texas60c10 is offline   Reply With Quote
Old 09-13-2016, 02:12 PM   #2
jtrichard
Re: 4 speed transmission crossmember
THIS should help you with your V8 conversion
http://67-72chevytrucks.com/vboard/s...d.php?t=624210
jtrichard is offline   Reply With Quote
Old 09-13-2016, 05:33 PM   #3
Greg63
Enjoy your truck
Greg63's Avatar
You should not need any crossmember. You already have a 3 speed manual so the clutch set up is the same (a different size disc may be in order) but the trans just hangs off the bellhousing with no crossmember for the tail shaft needed - just like the three speed you already have.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 09-15-2016, 09:17 AM   #4
64c10HotRodder
Even if you do need a different crossmember just modify your existing crossmember to fit. I had a 4 speed and replaced it with a TH-400 and all i did was modify old cross member
64c10HotRodder is offline   Reply With Quote
Old 09-17-2016, 01:47 PM   #5
oldusafmsgt
oldusafmsgt's Avatar
Yup, like Greg63 said, if you use your existing bellhousing mounts, no crossmember is needed. All 3 and 4 speed trucks just hung the transmission off the bellhousing with no crossmember. The only crossmember used in 60-62's was for automatics, and is very rare. Not too difficult to fab one up though.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 09-17-2016, 10:38 PM   #6
thunder71
thunder71's Avatar
Second generation camaro...perfect fit
_____________________________________
66 C10 shortbed stepside KEEPER
66 C10 longbed stepside SOLD
69 C10 shortbed stepside SOLD
71 C10 custom deluxe long fleetside SOLD
thunder71 is offline   Reply With Quote
