09-13-2016, 02:12 PM | #1 |
Need Trim Hole measurements
I'm in need of door and fender trim hole measurements.
I can't find any info on location and spacing of upper and lower trim holes for doors and fenders. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! lol, please! Rich
IT IS WHAT IT IS |
09-13-2016, 11:48 PM | #2 |
Re: Need Trim Hole measurements
I don't think I have the exact trim pieces you need, but I can give you another measurement to work off of. I just so happen to have a piece off right now. Not sure if it would help or not.
USCG "Support Search & Rescue, Get Lost" |
09-14-2016, 12:10 AM | #3 |
Good luck with that. You could use an assembly manual, but the reference points won't help you, at least not as intended, because you don't know what they measured from. If you can locate one or two holes top and bottom, then you can use the manual and your eyes to do the rest. Here's some info.
https://www.youtube.com/watch?v=5JQYAEa0OGw http://67-72chevytrucks.com/vboard/s...d.php?t=678671 http://67-72chevytrucks.com/vboard/s...21#post1971021 http://67-72chevytrucks.com/vboard/s...d.php?t=672793 http://67-72chevytrucks.com/vboard/s...d.php?t=612113 http://67-72chevytrucks.com/vboard/s...d.php?t=665133 http://67-72chevytrucks.com/vboard/s...d.php?t=179279
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-14-2016, 01:11 AM | #4 |
Well there ya go. Just needed to keep the post alive long enough for someone to come through with some useful info. Good luck with that trim...
09-14-2016, 10:25 AM | #5 |
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
IT IS WHAT IT IS |
