Old 09-13-2016, 02:26 PM   #1
Deer_hunter_088
Deer_hunter_088's Avatar
Exhaust?
okay so on my 69 k10 i need new headers (well specifically the drivers side one) and was wondering, what is the best type for cheap,mpg, sound, and hp, basically my exhaust is true duals, and soon to be glass packs and dumping under the bed,
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 09-13-2016, 05:14 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Exhaust?
I'm running Heddman hedders on a 350 in a '71 GMC Jimmy 4x4 with manual transmission [SM465/NP205]. It's at stock height, I think. I did have to have a machinist bend the ''ears' of the Z-Bar to clear the downtubes for the lower clutch pushrod to swing. Only drawback is having to pull passenger side header whenever I replace the starter, but that does not happen often.
Can't remember Heddman's p/n since this was 17 years ago that I changed out the PO's blown engine. I was on a budget but didn't want any Asian import parts. Also went with a Carter AFB [pre-Edelbrock] and Weiand 8004 intake [pre-Holley buyout]. H-pipe and dual exhausts thru turbo mufflers exiting behind rear tires
Still running.
Old 09-13-2016, 05:16 PM   #3
demian5
demian5's Avatar
Re: Exhaust?
I just replaced a set of hedman headers in my 70. They are for a C20/C30 but also cross over to a 350 conversion in a CJ-5 or 7. The collector is next to the frame so they are plenty high.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 09-13-2016, 07:38 PM   #4
Mike C
Mike C's Avatar
Re: Exhaust?
Hedman for sure if running a manual trans. In general they are a good value for the $.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-13-2016, 07:41 PM   #5
Deer_hunter_088
Re: Exhaust?
Trucks auto and well height ain't an issue bc its sitting on 8 in lift
1998 S10ZR2
Old 09-13-2016, 08:58 PM   #6
ElKotze
ElKotze's Avatar
Re: Exhaust?
Have you looked into SUMMIT-brand headers? I am running the ceramic coated ones in my '68 for four years now and no issues, around $250 I think. Just put the unpainted ones for $130 in my '69 work truck, you just have to paint them yourself. They fit great and sound good. I don't know who manufactures them but they are very solid.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline   Reply With Quote
Old 09-13-2016, 11:05 PM   #7
ripper70
ripper70's Avatar
Re: Exhaust?
I did Hedman Elite Thermal coated headers for my 4x4 build. I like em!
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 09-14-2016, 08:23 AM   #8
Deer_hunter_088
Re: Exhaust?
Thanks yall. gunna doo a lmore googling today. i don't need shiny i need function. and probably am buy a cheap set for now. I'm on an extremely tight buget.t
1998 S10ZR2
Old 09-14-2016, 09:34 AM   #9
TwoFiftyShifter
Re: Exhaust?
I think the regular headman headers are about $130 a set. That is your best bet.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 09-14-2016, 11:25 AM   #10
Deer_hunter_088
Re: Exhaust?
So my neighbor has a set of short tube headers for 75 bucks, will they fit on this truck?
1998 S10ZR2
Old 09-14-2016, 11:29 AM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Exhaust?
Shorties are no better than stock manifolds... if you want real headers, get the long tubes. Headman Hedders are good headers for the money.
I'd rethink glasspacks dumping under the cab...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-14-2016, 11:44 AM   #12
Deer_hunter_088
Re: Exhaust?
Gary
it currently has longtubes on it, just well one is broke, and looking for options on headers if i cant save em. and i was thinking it having dual glasspacks, with them dumping out right before the rear fender, or them dumping right behind the rear fender, as i have some salvagable pipe from the old exhaust.
1998 S10ZR2
Old 09-14-2016, 09:19 PM   #13
Mike C
Mike C's Avatar
Re: Exhaust?
Personally, I would spend the money on the 2 1/2" rams horns and move on down the road. I replaced my Heddmans with the 'vette manifolds and could no be happier.
I'm going out of my way to try and get a set of big block repro 'vette manifolds installed on the 427 I'm building for my 69 short step. Should make plenty of power, at least for my goal of 350 whp and be quiet and leak/maintenance free.
44 Willys MB
52 M38A1
64 Corvette Coupe
