Old 09-13-2016, 02:53 PM   #1
ztk123
2" solid aluminum lowering blocks and new U bolts
2" solid aluminum lowering blocks and brand new U bolts.
The blocks are machined to maintain the correct pinion angle.
$90 shipped in the conus.
Thanks,
Mike
ztk123 is offline   Reply With Quote
Old 09-19-2016, 02:48 PM   #2
ztk123
Re: 2" solid aluminum lowering blocks and new U bolts
Ttt
Old 09-21-2016, 07:04 PM   #3
ztk123
Any offers? Bought the blocks from a member for $50, new U bolts were $25, shipping in a rate box is $15.
Mike
Old 09-21-2016, 07:16 PM   #4
ck5566
Thanks,
Mike
What do you mean by "the correct pinion angle" I am new to this lowering thing, I also have coils all 4 corners.
ck5566 is offline   Reply With Quote
Old 09-21-2016, 09:41 PM   #5
ztk123
I will do my best to explain, anyone else that wants to explain better feel free. As your chassis is lowered or raised in some cases it changes the angle of the drive shaft from the transmission to the differential. Ideally you want to maintain what was the factory angle. This helps reduce the chance of stress on the universal joints and minimize driveline vibrations. The blocks listed have been machined so that as you lower the rear end that angle is maintained. There are several threads on the board related to pinion angles. Believe me, I'm absolutely no expert.
Thanks,
Mike
Old 09-21-2016, 09:59 PM   #6
ck5566
Thanks,
Mike
So what happens if you lower the rear with only using lowered coil springs? Would that also change the pinion angle?
Old 09-22-2016, 06:48 AM   #7
ztk123
Not really, the axle brackets are welded to the rear end at a pre established angle. If you were using just square lowering blocks it slightly changes the angle of the rear end. Therefore some people use shims to maintain that angle. In the case of these blocks the machining should eliminate the need for shims.
Thanks,
Mike
Old 09-22-2016, 11:02 AM   #8
ck5566
Thanks,
Mike
I get it know Thanks for the lesson.
Old 09-28-2016, 10:04 AM   #9
ztk123
Price drop $75 shipped conus
Old 10-02-2016, 08:43 AM   #10
ztk123
Offers?
Old 10-02-2016, 11:00 AM   #11
raggedjim
raggedjim's Avatar
Will you take $70 shipped to 42071?
Thanks, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 10-02-2016, 12:11 PM   #12
Livrat
Member #1049
Livrat's Avatar
If its get to me I'll take them for the $75.00 shipped
Livrat is offline   Reply With Quote
Old 10-02-2016, 09:51 PM   #13
raggedjim
raggedjim's Avatar
Mike, you should have paypal.
Thanks, Rg
Roger
'70 GMC Jimmy 2wd
Old 10-04-2016, 02:50 PM   #14
ztk123
Blocks sold and shipped to raggedjim.
Thanks,
Mike
Old 10-05-2016, 09:49 PM   #15
raggedjim
raggedjim's Avatar
Mike, got them today, Thanks!
Rg
Roger
'70 GMC Jimmy 2wd
Old 10-05-2016, 09:54 PM   #16
ztk123
Thanks to you as well!
Mike
