Old 09-13-2016, 09:50 PM   #1
Flysocal
Help with hood to cowl gap
Got the hood gap as close as she will get. Just wondering if anyone has suggestions to get it closer. It's about 1/2" at its worst. Should I extend the hood with some sheet metal? Or add to the cab/cowl?
Flysocal is offline   Reply With Quote
Old 09-13-2016, 10:25 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Help with hood to cowl gap
Without the front end on you have no idea how that hood fits. But to lower the rear, loosen the hinges and lift the hood up open as far as you can, then tighten the bolts. You will find that it is likely then too low, but you will get the idea.
But really, the fit of that hood relies on the hood latch on the rad support.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 09-13-2016, 10:49 PM   #3
dsraven
Have you seen/tried the method describedin the assembly manual?
Old 09-14-2016, 12:11 PM   #4
Flysocal
Your right. I'm jumping the gun here. I've been trying to get as much done with the cab before the frame comes back in the garage. With the frame in the garage its tight and hard to move things around. I will wait on sheet metal.
Old 09-14-2016, 12:15 PM   #5
MARTINSR
MARTINSR's Avatar
And forget the doors too until you have it bolted on the frame properly. The cab can twist easily believe it or not.
Brian
1948 Chevy pickup
Old 09-14-2016, 02:23 PM   #6
mr48chev
mr48chev's Avatar
The cabs twist rather easily, sometimes even when they are fastened to the frame.
If you don't have the Factory service manual I have the pages on adjusting the hood in this album, It's out of sequence but not hard to figure out. I'd suggest saving the pages to your computer so you can read them easier.
http://s173.photobucket.com/user/mr4...?sort=2&page=1
My ongoing truck projects:
Old 09-16-2016, 06:32 AM   #7
hogfarm
I agree you cant do nothing without the front fenders installed,but what I did find out after using the OEM way,it did not work. I had front end on truck,then I removed the springs leaving the hood to float. removed the latch,losened the hinges and slid the hood into place,then tightened the hinges.It was too easy,and gap closed right up.the front of the fenders can not be adjusted up or down.but rear can be moved up and down a bit
hogfarm is offline   Reply With Quote
