Old 09-14-2016, 03:58 PM   #1
Jcalvettide
1971 Cheyenne C10 - 350 v8 HEI distributor
I was looking to replace my original points distributor with an HEI type. I found a "CFR Performance - HZ-D6001" HEI distributor on Amazon for $64. Any advice on this manufacturer? Thanks..
Jcalvettide is offline   Reply With Quote
Old 09-14-2016, 04:10 PM   #2
leftybass209
leftybass209's Avatar
Re: 1971 Cheyenne C10 - 350 v8 HEI distributor
Welcome to the board!
I have no experience with that distributor. I have, however, had experience with both the Accel, and Proform GM licensed distributors. The Proform one was a much better build quality compared to the Accel. Both come in between $120-150 depending on where you find them.
Some folks have had good luck with the Skip White distributors, which are inexpensive as well.
It's not a drop in and go installation, as the wiring needs to be changed to facilitate a full 12 volts to the distributor. The current wiring has a built in resistance, that will not allow the HEI to function well, if at all.
leftybass209 is offline   Reply With Quote
Old 09-14-2016, 04:31 PM   #3
demian5
demian5's Avatar
Find one on craigslist that isn't beat up.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 09-14-2016, 05:01 PM   #4
JustToxic
JustToxic's Avatar
The CFR ones are cheap, I bought one for a demolition derby truck cause it was cheap. When I got it I didn't even use it due to how it was built. In the long run it'll be cheap to buy a Accel, MSD, or Proform. The Accel and MSD are sold at almost every Advance Auto in America so if you have issues you know you can find parts fairly local.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 09-15-2016, 04:03 AM   #5
cblock
cblock's Avatar
I got an OE of an 83 chevy van at my local pick ur part. Distributor, cap and wires for about $60, I even got the cable that goes to the ignition (because it had the terminal and I knew it was the correct gauge). Truck runs great and idles a lot smoother.
cblock is offline   Reply With Quote
Old 09-16-2016, 10:44 AM   #6
Jcalvettide
Thanks everyone! I think I will shy away from saving a few bucks and get a decent HEI :-)
Old 09-17-2016, 06:00 PM   #7
sKnNyPpY
sKnNyPpY's Avatar
I got a Skip White one as a cheap go between before getting something better and it has been going strong for three years now. Cheap and lucky, I guess.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 09-18-2016, 10:49 PM   #8
Myoldtruck
Myoldtruck's Avatar
Buy yourself a 12volt 30 amp relay with the plug and 6inches of wiring included, from ebay. I paid 10.00 for two of them new. Use the old power resister wire to turn on the relay, without removing the resister. Run a new hot lead fused from the battery to the relay, and then relay to the distributor. Just did this upgrade 2 months ago, working good.
Myoldtruck is offline   Reply With Quote
