Old 09-15-2016, 09:59 AM   #1
Gasasaur
Add Cab/Clearance Lights??
I think cab lights would look good on this truck, but lets face it, once you drill the holes there is no going back.
Looking for opinions. It's a real nice low mileage truck, so I'm extra nervous about it, but no guts no glory.
Should I do it?
Gasasaur is offline   Reply With Quote
Old 09-15-2016, 01:10 PM   #2
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Add Cab/Clearance Lights??
I added them to mine, I think it was well worth the effort. When you do it just make sure to do a layout of them before you drill any holes. After drilling I made sure to put paint on any bare metal.
I did use the newer style (88-98) rather than the style for (73-87) style, I just think they look cleaner.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 09-15-2016, 03:54 PM   #3
Gasasaur
Texas,
Did you use the clip on style nuts that place a threaded hole on the back side of the roof sheet metal, or did you use sheet metal screws that go directly into the sheet metal?
I heard there can be clearance problems because the electrical connection on the back side of the lights will not clear the headliner. Is that the case?
Thanks, would love to see a pic if you have it.
Gasasaur.
Old 09-15-2016, 06:07 PM   #4
83GMCK2500
Originally Posted by Gasasaur View Post
Texas,
Gasasaur.
I also installed GMT-400 cab lights on my '83. I'll have to look for pictures this weekend, I took some during install. It's a double wall roof, the harness is between the outer and inner skin, hence, no headliner interference. My '83 was mid-optioned, no headliner, so I ran the wiring down the A-pillar. As for fastening I used rubber well nuts.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 09-15-2016, 06:35 PM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
I put low profile smoke color led clearance lights on mine...I like them much better than the big orange soup bowl lights it had..got em off ebay
Old 09-16-2016, 02:48 AM   #6
andrewmp6
I'm not a fan of them unless you have to have them,The old reason for them was 3 yellow or red lights close in a row was to warn other drivers of a trailer thats wider then 8 feet.I have seen people put them on everything from a ranger to a jeep grand cherokee.
andrewmp6 is offline   Reply With Quote
Old 09-16-2016, 07:37 AM   #7
TexasJeff
TexasJeff's Avatar
Like Devin mine has no headliner, and it is just as he said, double steel roof, and the wires feed down the a pillar then into the fuse box. I did use the u clips nuts for my screws, I thought that better than just into the sheet metal. I will have to check if I took pictures or not, I took pictures of most of the build so I bet I have some.
TexasJeff
Old 09-16-2016, 12:32 PM   #8
Gasasaur
Are the holes in the roof the same whether you use the older style correct lights or the newer style found after 88? I prefer the look of the new lights, but want to make sure they can be swapped out for the "correct" ones.
I assume you used a pattern you made off of a truck that came with these lights so you could lay out yours?
Old 09-16-2016, 04:18 PM   #9
83GMCK2500
Here's a write-up on the 88-98 style install that a friend of mine wrote: http://www.gmt400.com/threads/cab-light-install.117/ on his '88. Note: the spacing will be different for a square.
The square body style screws are transverse to the truck, the 88-98 are longitudinal. Converting from one to the other would require filling holes, drilling new ones. When I drilled my cab I used the large hole or grommet center for my spacing/alignment of them and then used the measurements in that write-up for screw position.
Devin
New Daily, the '96
Old 09-16-2016, 04:39 PM   #10
mongocanfly
Post Whore
The factory holes for the lights are recessed on my truck..luckily the new lights i put on covered the depression..the screw holes for factory are on the sides of the lights..the new ones I used are front and back..
Old 10-03-2016, 02:02 PM   #11
83GMCK2500
Found a few pics, here's setup and layout.
Installed
Devin
New Daily, the '96
Old 10-03-2016, 11:42 PM   #12
86454k30
86454k30's Avatar
As much as I like cab lights, if that is as clean as it looks in the pictures and it is low mileage I wouldn't add cab lights...my 2 cents. Nice truck!
86454k30 is offline   Reply With Quote
Old 10-04-2016, 06:06 AM   #13
Gasasaur
Where did you get the spec's for laying out the lights? Did you measure from another truck or wing it?
Old 10-04-2016, 09:43 AM   #14
hatzie
Moderator
hatzie's Avatar
If you want a nice clean hole with straight edges get one of the Klein carbide tipped hole saws. They're pricey but very worth it.
I use them to drill 1-3/8" & 7/8" antenna holes in metal transit coach roofs. I've picked em up at one of the usual suspects... Lowes or Home Depot or ACE or True Value.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-04-2016, 01:55 PM   #15
SCOTI
SCOTI's Avatar
I don't care for cab lights for the same reason I don't like sun-roofs or T-tops..... Anywhere there's a hole in a roof, sooner or later there will be a leak from said hole. I absolutely would not poke holes in a roof for lighting.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-04-2016, 02:32 PM   #16
83GMCK2500
Both. Because the bolt patterns are 90 degrees from each other I measured the large hole that the grommet & harness occupy and started there, adjusting for fitment, curvature, aesthetics.
Attachment 1577782
Have you seen a 1-3/16" in that flavor? I clean up the holes I make with a deburring tool, doesn't take much but I wouldn't mind using a better hole saw.
Devin
New Daily, the '96
Old 10-04-2016, 02:49 PM   #17
hatzie
Moderator
hatzie's Avatar
You can get em down to 5/8"
1-3/16" may be difficult. Slightly bigger or slightly smaller either 1-1/4" or 1-1/8" will likely do just fine.
I use those tools all the time to break sharp edges. It takes less time if the holes are pretty clean to begin with.
