![]() Join Date: Jul 2010
Steering column terminals
Does anyone know where I can find the terminals in a steering column plug? Or tell me what exactly they are called. I had to replace a section of wire on the truck wiring harness going to the column and it was too short to use a butt connector . And old terminal is unusable.
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
#2 | |
The Older Generation
Re: Steering column terminals
The terminal you are looking for is called a "Twin Lock" terminal. It has no gender, since it mates with itself. Twinlock terminals have 2 locking tangs that must be depressed before you can pull the terminal out of the connector. The best tool to use to push down the tangs is a small jewelers screwdriver that is about .050" in diameter. Once the tangs are pressed down, the terminal should come out easily. The original part numbers for the terminals are: 02973915 18-20 Gage 02973916 14-16 Gage 02973917 12 Gage http://www.mouser.com/ProductDetail/...ZGgjACbw%3D%3D LockDoc
![]() Join Date: Mar 2003
I just rewired a truck, I could pull a section of wire out of the harness, you could butt to that. Just the cost of shipping......... about 3.00
