09-16-2016, 01:45 PM | #1 |
Tire size on 4/6 ECE drop
I am planning on running 20X8 245/45 in the front and 275/45 in the rear, does anyone know if this will be an issue? I am in the process of lowering the truck with the ECE Drop spindles and coils and wanted to go with the tire size stated above.
09-16-2016, 09:53 PM | #2 |
A guy with a truck
Re: Tire size on 4/6 ECE drop
It will be close, depending on the back spacing of your wheels. I ran 255/45 and 295/45 on a similar setup and cleared just fine. It's all about the measurements. Most trucks you see with 40-series tires
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
