Old 09-16-2016, 06:55 PM   #1
badherb
badherb's Avatar
Ididit is incorrect
"Original Chevy Truck Steering Wheels Original 1960-66 steering wheels will NOT fit on top of any ididit 1960-66 Chevy truck column. With the help of ididit’s 1955-68 horn kit w/ ring, a stock 1967-72 wheel will bolt to your 1967-72 ididit steering column. The 1973-78 stock steering wheel will bolt directly to the top of an ididit steering column with no additional accessories or modifications."
I modified my original 60 steering wheel and what do you know it works self cancelling and everything.
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 09-16-2016, 08:21 PM   #2
PGSigns
PGSigns's Avatar
Re: Ididit is incorrect
So what did you mod? Got any pictures?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-16-2016, 08:38 PM   #3
AUS64c10
I'd be interested in seeing this as well. I have my original deluxe steering wheel sitting in a box gathering dust but would love to fit it back to the truck.
AUS64c10 is offline   Reply With Quote
Old 09-17-2016, 11:17 AM   #4
badherb
badherb's Avatar
Its easier than you would think. The self cancelling dohickey on original wheel is clocked to about 2 on the wheel. My wheel has 6 holes. 3 to hold the horn button and 3 that vary in size. One that is too small for the new self cancelling dohickey is at the 10:30 position that Ididit says the clocking position needs to be at. I took a size V drill bit and hogged that hole out. It now fits over the self canelling/horn dohickey.... Also important is the spine count. Im not sure all chevy wheels have a 36 spline but mine did and so does the Ididit column.
To make sure everything will work before you drill anything turn yer wheel 90 degrees with the self cancelling/horn dohickey at 1030 slip the wheel on. A little wiggleing and the wheel should fit. If you have a fit drill as prescribed above and the wheel should be straight and self cancel will work. Ididit also provides a chrome ring in the horn button kit you need to purchase that yer supposed to caulk in place. That does not fit. And will need to not be used. A few test fits and you will see. Or you might get lucky. I wasnt.
1960 SWB “Pops”
Old 09-17-2016, 11:18 AM   #5
badherb
badherb's Avatar
Sorry pic is side ways
1960 SWB “Pops”
