Old 09-16-2016, 11:20 PM   #1
60burb4me
rear end difference
does anyone know the differences in the gap between the mounting pads on a 1960 to 62 rear end and a 63 to 72 rear end? I am trying out figure out the space difference.
60burb4me is offline   Reply With Quote
Old 09-17-2016, 08:26 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: rear end difference
Space is an issue but the angle of the mount could also be an issue
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-17-2016, 09:31 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
There also at an angle so at what point would the gap be measured?
Old 09-17-2016, 10:10 AM   #4
60burb4me
correct. I know the length of the trailing arm (the are the same.) so if I can get the gap from the backside of the mounting pad or the ends of the 2 trailing arms I can figure out the different angles. which is ultimately my goal. I have a 60 so I need the gaps on a 63 to 72.
Old 09-17-2016, 11:42 PM   #5
Captainfab
60-66 Nut
I really don't understand what this 'gap' is that you are talking about.
Old 09-17-2016, 11:54 PM   #6
60burb4me
either the gap between the 2 mounting pads on the rear end, or the gap between the rear end of the trailing arms either one will work.
the gap between the front mounting points of the trailing arms would be great but I can figure that out if I need to.
Old 09-18-2016, 12:16 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Maybe this might help
http://67-72chevytrucks.com/vboard/s...10#post7357010
66 C20 Service Truck:
Old 09-18-2016, 12:26 AM   #8
60burb4me
thanks, but what I need is the measurements I have the length of the trailing arm, I have the gap of a 60 to 62 I need the gap of a 63 to 72 so I can explain the different angles of the separate years
