09-17-2016, 05:58 PM | #1 |
Who's running Chevorn Delo in their motor
Just wondered if anyone is running Delo oil in your rebuilt vintage motor for the good zinc/phosphorus content which protects against wear
Delo LE 15-40 , zinc-.13, phosphrous .12 the old Delo multigrade(not LE) 15-40 , zinc- .15, phos.- .14 Most the new low emission oils the highest content is zinc .08 or less, phos .77 or less. Less for synthetics and syn/blends Valvoline ZR1 racing oil is zinc 13-14, phos. .12-.13 Brad Penn oil is zinc .15, phos .14
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
09-20-2016, 12:45 AM | #2 |
Re: Who's running Chevorn Delo in their motor
I ran Delo in the 396 with flat tappet hydraulic lifters for a few years with no problems.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
09-20-2016, 05:59 AM | #3 |
Post Whore
A long long time ago I used shell rimula straight 30w..ran that a few years and then switched to delo straight 30w...ran that in all my trucks and tractors for years and years..one of those trucks had 285k miles another had 235k and a few others up around 200k when I got rid of them..never had any internal engine problems...absolutely no complaints..but now I'm a believer in synthetic so that's what my stuff gets now..
09-24-2016, 11:11 AM | #4 |
Have been running Delo since the 70's in fleet applications & personal use, both straight weight & multi-vis, everything from small to big. Good oil, can't go wrong with it. All the commercial grades still have a fairly high zinc content but they are reducing the zinc amounts also. Our oil options with flat tappet motors are becoming fewer & fewer. At this point we basically have 3 options:
1. run commercial grade oil (diesel grade) 2. use a boutique brand (redline, royal purple, amsoil, etc) 3. use a zinc additive We still have to monitor content because, just as you pointed out, the Delo LE has less zinc than the old. Bob's the Oil Guy is a great web sight that has more info/data on oils than you'd ever want to know. Some of it is dry reading but very insightful. When I have insomnia that's what I read! I was in fleet maintenance for years, now I own a quick lube, tire & repair shop. I work on a lot of older rigs/ classics / hot rods so I am forced to stay up with the zinc content in oil - boy, that sounds boring! |
09-24-2016, 06:26 PM | #5 |
I actually ordered 2 bottles of Zddp-plus, But,
I instead I'm going to run Delo. I already use Delo in my Dodge Cummins 4x4 Its only about $12.50 a gallon at walmart B.W. I sent you a PM
09-24-2016, 07:33 PM | #6 |
Post Whore
I meant to add to my above post that I still run delo 400 30w in all my tractors..
09-26-2016, 05:42 PM | #7 |
I do - 15/40 & Wix filter!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
09-29-2016, 04:42 PM | #8 |
I run straight 30W in my Boat 7.4 liter for the last 20+ years
GK10 Gary |
10-15-2016, 09:34 PM | #9 |
I have been running delo 400 15/40 in all my vehicles for over 15 years , all gas engines, have had good luck with it...
01-29-2017, 02:29 PM | #10 |
20 years on Delo 400 (mostly in 15w-40) in everything. Wix filters too.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
01-29-2017, 08:27 PM | #11 |
Running 15/40 rotella in all my vehicles and thinking of a switch to Chevron delo. Anyone know how they compare to each other?
01-29-2017, 08:38 PM | #12 |
01-29-2017, 08:40 PM | #13 |
Price wise they're the same, I mean compare as far as quality/which is better?
01-30-2017, 10:42 AM | #14 |
Internal engine failure due to wrong brand/type of oil is rarely a problem in our vintage trucks...in my opinion. All the additives and such are a waste of money, again my opinion only.
This is only from my experience and observations from having been in the automotive business for many years and having owned many many Gas and Diesel engines. |
