Old 09-17-2016, 06:19 PM   #1
beautimus
beautimus's Avatar
rear axle question
I have a 71 with 3.08 positraction 12 bolt truck rear (3.07?) and its gonna need more
Gear. Can i go to a 4.11 or higher gear set in this housing? Or do i have to keep
It 3.73 or below? Anybody know for certain? Thanks,Tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 09-17-2016, 07:48 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: rear axle question
The housing is fine but you'll likely have to swap the carrier.
Tyler
57taskforce is offline   Reply With Quote
Old 09-17-2016, 10:45 PM   #3
Mike C
Mike C's Avatar
I ran thick 4.10 gears in my Jimmy when it still had the 12 bolt. You can buy gears that will work with your 3 series carrier.
But if you have a 4 series you can't go numerically lower as the gears would be too thin.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-18-2016, 06:23 AM   #4
beautimus
beautimus's Avatar
thanks guys, thats what i needed to know, Tony
Old 09-18-2016, 03:57 PM   #5
scooterpimp
scooterpimp's Avatar
Not tryin to thread jack , but does anyone know torque spec on spider gear pin lock bolt on same setup? 71 c10 12 bolt. Did axle bearings & seals. I searched hi & lo cant find any spec on bolt.
scooterpimp is offline   Reply With Quote
