tranny swap
Has anyone swapped out the th350 for the 200-4r
I would love an overdrive in my 72..thanks |
Re: tranny swap
This will help with dimensions
http://www.maliburacing.com/tranny_i...dimensions.jpg
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Re: tranny swap
Yep, I've done that swap. Crossmember moves back but if I recall it saves the driveshaft, as they're the same overall length, and use the same yoke. So it's as close to a bolt-in as you're going to get for an overdrive trans swap.
Make sure you're diligent about the TV cable. It's not just a kickdown, it controls clutch pressures and everything. One trip around the block with it misadjusted can wipe your trans.
The Older Generation
Re: tranny swap
Here are a couple of threads on it. One of them is davepl's http://67-72chevytrucks.com/vboard/s...d.php?t=540257 http://67-72chevytrucks.com/vboard/s...d.php?t=542624 If you type 2004r into the Google search box above, click on the circle in front of 67-72chevytrucks.com, and click on the Google button you will find quite a few threads about it.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-18-2016 at 09:26 PM. |
