Old 09-18-2016, 03:45 AM   #1
396C-10
3 speed manual to T-400 conversion trans yoke?
I have put a T-400 auto trans in place of the 3 speed manual and everything is bolted in but the drive shaft. It is measured, shortened and balanced ready for install. I will need a cross-over u-joint until i can swap the yoke. Does anyone know the part number or ID on this u-joint?
396C-10 is offline   Reply With Quote
Old 09-18-2016, 07:26 AM   #2
notsolo
notsolo's Avatar
Re: 3 speed manual to T-400 conversion trans yoke?
I got mine from Denny's Drive shafts.http://www.dennysdriveshaft.com/c142...32_x_3_58.html
notsolo is offline   Reply With Quote
Old 09-18-2016, 02:37 PM   #3
396C-10
Thank YOU! This saves a lot of fuss!
Old 09-19-2016, 09:39 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
What do you mean swap the yoke? On the diff?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-20-2016, 10:56 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
If it doesn't have the tranny yoke on it, it isn't balanced..
You need to figure out what kind of ujoint the tranny yoke is and what kind of ujoint the driveshaft is (probably 1310) should have had the driveshaft shop put the right weld yoke in the driveshaft that matches the tranny yoke.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-21-2016, 12:03 AM   #6
396C-10
On the trans.... This is a temporary fix for right now.
Old 09-21-2016, 12:05 AM   #7
396C-10
It has the trans yoke, just a different size. I will jump joint it for now until I figure out a plan.
Old 09-22-2016, 01:31 PM   #8
brad_man_72
the boat guy
Just like if you change tires on a wheel you change the balance.
If you change transmission yokes you change the balance of the divshaft even if you use a conversion joint... or even if you use the original joint.
If you're able to measure the ujoint I can give you part numbers or even sell you one. But even if your but dyno doesn't feel a vibration that doesn't mean that you aren't risking damage to the transmission. Its best just to do it right the first time.
Old 09-23-2016, 12:31 PM   #9
396C-10
Thank you!
