Old 09-18-2016, 06:46 PM   #1
nitrosport_5
nitrosport_5's Avatar
1972 C30 Dually Eaton Rear brake backing plates
i removed these from my 1972 c30 when i changed over to a square body rear brake. these are dirty and grimey but still solid. $20 plus the ride
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 01-26-2017, 10:20 PM   #2
chevymom53
Re: 1972 C30 Dually Eaton Rear brake backing plates
Looking for rear drums, 13.250 for 72 chevy dually c30?
chevymom53 is offline   Reply With Quote
Old 01-26-2017, 10:54 PM   #3
nitrosport_5
Sorry, my drums were junk. The brake hardware had fallen out and put a 1/2" deep groove in the drums.
I swapped the entire brake setup from a early 80s square body 1 ton dually onto my 72. Any GM 14 bolt dually can be used as a donor. use all the brake parts from the square body, and the bearing carriers/spindles and axle shafts from your 72. I recomend the swap, parts are much easier to find!!
