Old 09-19-2016, 08:03 PM   #1
T-P Auto
cab mounts
Hello;
Would like the measurements on where the cab mounts should be placed on a S10 frame for the 1948-1950 chevy/GMC pick up cab
T-P Auto
T-P Auto is offline   Reply With Quote
Old 09-19-2016, 09:49 PM   #2
av8tr33337
av8tr33337's Avatar
Re: cab mounts
Here is a video I did on locating my cab mounts. There are others here that will chime in that have very good pics and description on their build threads. Pay attention to the "oval hole" on the outside of your frame. That will get you close on mounting the front cab mounts. I mention that in the video as well. Do your research and look at what other have done and decide how high or low you want your cab to be off the frame. https://www.youtube.com/watch?v=cdgYy5YtW8k
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 09-19-2016, 10:21 PM   #3
HUSSEY
HUSSEY's Avatar
Re: cab mounts
I used Bartman's reference, turned out perfect. Thanks Bartman!
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 09-19-2016, 10:40 PM   #4
av8tr33337
av8tr33337's Avatar
Re: cab mounts
Thanks Hussey I was hunting through threads because I couldn't remember who it was that did such an awesome job on documenting their cab mounts. I finally found it. It was YOU!
During mock up I put 4X4 blocks between the cab and the s10 frame to get an idea of where I wanted my cab to sit. The 4X4 blocks actually measure 3 1/2 X3 1/2. I liked the look so I went with it. I'm also using the original s 10 cab mount bushings so my overall height from the frame to the bottom of the cab will be closer to 4 or 4 1/2 inches.
"Hussey" has a really nice build and did a good job of documenting the cab mounts. Check out all of Hussey's build but here is a link to the cab mount section. http://67-72chevytrucks.com/vboard/s...3&postcount=50
av8tr33337
1951 3100 Pickup
Old 09-20-2016, 02:48 AM   #5
T-P Auto
Re: cab mounts
Hello;
Thanks to both:
Hussey
N
av8tr33337
For the help needed;
I have booked marked the infor;
T-P Auto: chevy:
Old 09-20-2016, 03:28 PM   #6
joedoh
joedoh's Avatar
Re: cab mounts
have you seen skymangs thread? http://67-72chevytrucks.com/vboard/s...d.php?t=632686
he gives a good primer on mounting. keep in mind your mount measurement to the oval hole will depend on the width of the mounts you use.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
