Old 09-19-2016, 08:24 PM   #1
testerdahl
Custom Rear Bumper Tail Lights Needed
Alright guys, I have an odd issue with my '62. Turns out grandpa put an aftermarket rear bumper on the truck. Looking closer at it, there are 4 lights (2 on each side) with the openings being different sizes. A quick tape measure shows the big one is 3.5" and the other is 2" if memory serves right.
I have red and black wiring going to the rear bumper. Unfortunately, the current lights don't have screw holes. And it is a bulb which means the flat covers don't work. I'm starting to look at Semi lights as an option, but I have no idea if they will work. Here is one of the Semi ideas (http://www.raneystruckparts.com/2-ro...-marker-light/). I'm thinking I could make all 4 lights the same size.
Here is a picture showing the bumper. I can take a closer pic, but I thought this would get the conversation going.
Anyone have any ideas? I've been all over LMC, Classic Chevy and Napa. I can't figure out what I want or can do.
testerdahl is offline   Reply With Quote
Old 09-19-2016, 08:30 PM   #2
jtrichard
Re: Custom Rear Bumper Tail Lights Needed
Pull one of the lights out and get close up pics of light and what ever kind of mounting that is in the bumper....
Look at post #45 here
http://67-72chevytrucks.com/vboard/s...=561195&page=2
jtrichard is offline   Reply With Quote
Old 09-19-2016, 08:35 PM   #3
AcampoDave
AcampoDave's Avatar
If I were going to tackle that one, I would find a sealed light with a diameter that inserted into the original holes. Barring that option, I would find one that is a tad larger and secure it behind the opening with a homemade bracket of some type. I would also use an l.e.d bulb so I wouldn't have to mess with it again for a long time.
AcampoDave is offline   Reply With Quote
Old 09-19-2016, 08:38 PM   #4
testerdahl
Here are some close-up photos.
Old 09-19-2016, 08:41 PM   #5
testerdahl
Photos posted.
Sweet. A Barden bumper then. Thanks for posting that link. Interesting to see how those lights are in it.
Old 09-19-2016, 08:41 PM   #6
testerdahl
I should add my lights aren't flat like his. They are more like a tear drop.
Old 09-19-2016, 08:44 PM   #7
testerdahl
I'm also trying to find a mid 80s to early 90s S-10 with the 5-speed to do the swap with the 4-speed. If I do that, then I'll also get the neutral switch to do a reverse. With the strong possibility of my kids driving this truck someday, I'd also like to have a reverse light. This only further adds to the complexity. SMH...
Old 09-19-2016, 09:35 PM   #8
jtrichard
IF you could get the big holes cut out to 4-1/2" nice and round I would go to a light like this http://www.ebay.com/itm/2-RED-ROUND-...ZTgqCb&vxp=mtr
And 2-3/4" for backup lights
http://shop.poisonspyder.com/2-1-2-L.../41-04-300.htm
Old 09-19-2016, 09:38 PM   #9
testerdahl
I'm starting to wonder if it even matters if the whole light doesn't shine through. I mean I think I have enough room to put a 4 inch LED in the housing. The viewable light would be less, but would that really matter?
Old 09-19-2016, 09:40 PM   #10
testerdahl
I also wonder if I could just make these RV lights work. I would just need some way to mount them to the inside of the bumper. Hmm...
https://www.superbrightleds.com/more...onnector/2921/
Old 09-20-2016, 09:13 PM   #11
64shortbox
64shortbox's Avatar
How about something like this - looks like a mounting bracket on the back of the housing - a little larger than you are looking for but it just might work and for $3.80 from Home Depot not a lot of cash out of pocket to experiment with.
http://www.homedepot.com/p/Blazer-In...55UW/202498003
Then there's this one too - though you would have to open up the bumper hole to 4 1/4" but it is a surface mount and $3.98 out of pocket. Also from Home Depot.
http://www.homedepot.com/p/Blazer-In...KcMHgg&cj=true
64shortbox is offline   Reply With Quote
Old 09-20-2016, 09:21 PM   #12
testerdahl
Hmm... Those are great ideas. Thanks for finding them. Honestly, I wouldn't have even thought to look for Home Depot RV lights. I'm going to order up one and see how it fits. Thanks!
Old 09-20-2016, 09:35 PM   #13
64shortbox
64shortbox's Avatar
I found one more for you 3 3/4" round with 2 mounting studs but they're $17.00 a pair off eBay with free shipping - still not exactly what you're looking for but the more options you have the better - I know - still 1/4" larger than your opening but I thought I would throw it out there for you to check out anyway.
http://www.ebay.com/itm/Round-Red-Li...xSXb5u&vxp=mtr
Old 09-20-2016, 09:46 PM   #14
testerdahl
Thanks for finding these? I think I like the Home Depot ones better. I just wonder if I install 4 of them if it will work with the light illuminating behind the opening especially for the smaller ones.
Old 09-20-2016, 10:05 PM   #15
64shortbox
64shortbox's Avatar
I also like the 3 7/8" lights. I think they would be a better fit for your truck & bumper. I wouldn't think there would be a problem with them sitting behind the holes with giving out enough light - though there might be some red illumination from under the bumper at night - just not sure about that though.
