Old 10-07-2003, 08:22 PM   #1
1968GMC
love my truck
1968GMC's Avatar
1988 caprice, what transmission?
I have a chance to buy a 88 chev caprice 6 cyl for $200. Does/should it have a 700r4 transmission, and did they come with anny other trans? Also, I immagine its a 4.3 correct me Im rwong but if it is will the serpentime belt set up work on my 350.And for stupid question #3, can I use the rear end from the car? I know the bolt paturn is not the same as a truck but at least it will be 5 bolt. Whil Im at it will the front rotors work on i lowerd spindels? Sorry for all the stupid questions.
1968GMC is offline   Reply With Quote
Old 10-07-2003, 09:22 PM   #2
Leinie
I'm guessing it is a 200r4 tranny. It is a 4 speed overdrive built for light duty in rear drive cars. It has no provisions for changing the tail from 2 to 4 wheel drive like the 700r4. Cant help with your other questions
Leinie is offline   Reply With Quote
Old 10-07-2003, 09:29 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
I'll guess it's a 200-4R as well, the 87 caprice trans I have was behind a 305, and it's a 200-4R.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-07-2003, 10:34 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Actually, if the engine is the 4.3, the belt set up should work. Don't forget to swap over the water pump and fan assembly too. (They rotate backwards)
Old 10-07-2003, 10:45 PM   #5
dinnut
dinnut's Avatar
now thats interesting
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-07-2003, 11:23 PM   #6
fast67chevy2002
Dad's little helper
fast67chevy2002's Avatar
I don't want to steel the thread, but how do you tell the difference between a 200R4 and a 700R4, I pulled a 305 and tranny w/ od out of a 84 caprice and a 350 and tranny w/ od out of a 86, how do I tell what I have?
too many projects:
61 biscane
67 swb(shaved)
73 Fiat spider 124 Sport
84 Pontiac Grand Prix
86 olds cut. sup.
fast67chevy2002 is offline   Reply With Quote
Old 10-07-2003, 11:51 PM   #7
Longhorn Man
Take a look at the pan.
Old 10-08-2003, 10:00 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, the belt setup will work. I've done lots of V6 to V8 swaps in late models. Like was said, make sure and use the water pump too, because it turns backwards. V6s use a different harmonic balancer. Use the right V8 one and everything is bolt on.
Old 10-08-2003, 07:04 PM   #9
1968GMC
love my truck
1968GMC's Avatar
thanks guys for your ansers. Will a th 200 r4 work?
Old 10-08-2003, 07:38 PM   #10
Leinie
As long as it's 2 wheel drive you could use a 200r4, As long as your not pumping too much power. I don't know if you can get a high performance build done on a 200 or not. Check with a good tranny shop.
Old 10-08-2003, 10:34 PM   #11
Longhorn Man
You can get plenty done to a 200 4R. They are better than the 700 R4 in some ways, yet worse in other ways.
It is an easy one to fit in though. Place the crossmember in the TH400 location, and use a drive shaft for a TH350.
Then all you have to do is worry about adjusting the TV cable properly and hooking up the lock up converter. (don't leave it disconnected...it'll slip too much in OD)
Old 10-09-2003, 12:56 AM   #12
ABHaulR
ABHaulR's Avatar
i have a 2004r in my sub. it has a 350 with 40 inch tires. it works great, yes the tail shaft is fixed but when you use a 2 1/2 ton transfer case(divorced) it doesnt matter. the weight saved was worth the problem. as for strenght, at bowtie overdrives they say a 2004r will hold up to 470hp when built right. the nice thing about an OD is you cane go as big a gear as you want and still have the freeway gear to cruise. and it is a direct drop in for the th350. the 2004r has two different bellhousings. a universal and the chevy,
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
