Old 09-20-2016, 02:12 PM   #1
cjoenny89
cjoenny89's Avatar
how to remove gas tank level switch
Is there an easy way to remove the gas tank level float switch? Do I need a tool to remove the clip that holds it in? Is there anything special I need to do to get it out?
I think I will have to remove the seat to get it out. any suggestions would be helpful. I am going to replace the float portion on it. I think from what I trouble shot on it from your help last time we figured my float was bad.
anyway I need to remove it to find out.
cjoenny89 is offline   Reply With Quote
Old 09-20-2016, 02:28 PM   #2
Deer_hunter_088
Deer_hunter_088's Avatar
Re: how to remove gas tank level switch
i just moved it around with a hammer and screwdriver, but BE CAREFUL to not spark it.
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 09-20-2016, 03:18 PM   #3
cjoenny89
cjoenny89's Avatar
Old 09-20-2016, 03:28 PM   #4
Deer_hunter_088
Originally Posted by cjoenny89 View Post
anytime, but put some electrical tape or something on the tip, just to be safe, so it dont spark, because if it does and the spark hits a pocket of fuel vapor then well poof.
1998 S10ZR2
Old 09-20-2016, 03:30 PM   #5
cjoenny89
cjoenny89's Avatar
Great idea I will wrap it in electrical tape or look for a brass punch
Old 09-20-2016, 03:36 PM   #6
Deer_hunter_088
ive still sparked with brass, it sparks and you could be toast, look at how little a spark a spark plug makes.
1998 S10ZR2
Old 09-20-2016, 10:22 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: how to remove gas tank level switch
Take the ring off with a punch have a fan blowing across you while doing it to keep fumes out. Blow the fan from passenger side to drivers side to keep tank fumes away if coming out of filler hose.
I have used pliers to get them loose also.
Once its loose just unhook the wire and twist it out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
