Moderator
![]() Join Date: Dec 2012
Frame stamp help
Working on my buddy's truck, and came across the frame stamp under the passenger door. Wondering if someone can help me decode it. I think the last few digits are obvious:
3829596 10 2 62 Are the first group of digits a partial VIN? |
Re: Frame stamp help
look like a part nbr... otherwise they would match the nbrs on the serial plate
ron |
Moderator
![]() ![]() Join Date: Aug 2011
VIN Number locations including frame: http://67-72chevytrucks.com/vboard/s...d.php?t=316902
![]() ![]() Join Date: Apr 2012
Ron is correct 3829596 is the frames part number the other numbers are the date . These are stamped on the side of the frame . The VIN is on top of the frame.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Moderator
Perfect, thank you gentlemen, I'll check the other side for the VIN tomorrow! Can't believe how clean this thing is. Looks like it was stamped last month.
chev or gmc. if it is a chev it will all be on the drivers side on top by where the steering box is or by the rear cab mount
ron |
Moderator
Ok, here's what's on the frame:
0107330 Looking at the decoder... I'm not sure how to break it down. It's likely a Canadian truck if that helps... |
does it match the back part of the ser#
ron |
I'm think #107330 of the line
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
