Old 09-20-2016, 09:30 PM   #1
clemsonteg
A-arm bushing steel sleeve
I am working on a set of 73+ lower arms and I am to the pint that I am removing the shafts to replace the bushings. I got the shafts out by drilling holes around the rubber and pounding them out. The outer sleeve of the rubber bushings are still in the arm. Any tips for removing these? I can tell that the inside portion has the edge pinged, so I am guessing I need to bend that edge back in before I can get the sleeves out.
clemsonteg is offline   Reply With Quote
Old 09-21-2016, 09:44 AM   #2
bluex
bluex's Avatar
Re: A-arm bushing steel sleeve
As long as you dont need to reuse that sleeve heres how I got mine out. I took a hack saw and put the blade through the sleeve and then hooked it to the saw frame. Cut a notch in it and then you can take a chisel or a punch and collapse it and it will fall right out.
bluex is offline   Reply With Quote
Old 09-22-2016, 06:50 PM   #3
clemsonteg
Good call on the hack saw. That worked great. As far as I can tell, the rubber bushing and steel sleeve are intended to be a single unit. I think the poly bushings are a 3 piece setup that is assembled during the install.
Old 09-23-2016, 10:58 AM   #4
SCOTI
SCOTI's Avatar
The Energy Suspension poly bushings I've done in the past would/could re-use the original sleeves based on the app. I always check first to save the extra labor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-23-2016, 11:31 AM   #5
clemsonteg
I haven't quite decided if I'm going to to poly bushings or go back with rubber. I was looking at the Moog rubber bushings since the rest of my suspension that I have rebuilt is all Moog.
Old 09-28-2016, 10:27 AM   #6
SCOTI
SCOTI's Avatar
FYI.... I believe Ride tech will be offering a Delrin replacement bushing for C10's this fall. If performance type responsive steering/handling is desired, I would check into them.
If not, the replacement rubber bushings will require removing the old shells.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
