drag it like you stole it
removing key cylinder..
i have a tilt van column in my truck, and it has the key cylinder on the column. is there a way to remove it? i already have a cylinder mounted in the dash i am using.
negative camber //LA\\ |
If you are just trying to remove the cylinder from the column.........there is a retaining keeper inside the column.
I would say that the outer collar might have to be reworked to get it smooth.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
huh?
![]() Join Date: May 2000
I bet someone on the 73-87 board will know, that series of truck has the ignition cylinder in the column.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
You have to pull the wheel and retaining plate. There is a small "c" clip that holds it in. Then remove the turn signal switch. After that, there is a small set screw that holds the cylinder in place. Remove that, and pull out the cylinder. On some models it is not necessary to remove the t/s switch. Good luck. If ya need pics, let me know.
John
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
thanks fellas
