Old 09-21-2016, 12:38 AM   #1
Vandals909
4l80E in 67-72 Which tilt column?
Truck has a regular column now. Was wondering which aftermarket or maybe a Kev's Classic is better?
I would like the lock outs for each gear to be there. Also when in drive not be down to low.
What experience do you guys have with which columns work best with a 4 speed auto? Might also want one a little shorted then the one I have now, its pretty close to me.
Vandals909 is offline   Reply With Quote
Old 09-21-2016, 03:21 AM   #2
ls1nova71
ls1nova71's Avatar
Re: 4l80E in 67-72 Which tilt column?
I would definitely suggest getting one from Kevs Classic over one of the new repop columns. A rebuilt converted van column will be way nicer than those chinese junk columns in my opinion.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-21-2016, 10:21 AM   #3
Vandals909
Any idea if the stock replacement will work good with the 4speed 4l80e
Old 09-21-2016, 11:33 AM   #4
truckdude239
truckdude239's Avatar
Im using a stock van tilt in mine
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-21-2016, 11:44 AM   #5
Vandals909
What's the difference Between the truck and the van tilt
Old 09-21-2016, 03:16 PM   #6
davepl
davepl's Avatar
I'm running a factory 1970 tilt with a 4L80E but we wound up fabricating our own brackets for the shift rod. The gear selection is pretty much perfect on the 4-speed repro lens.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-21-2016, 03:44 PM   #7
Vandals909
Do you have a picture of it mounted?
Are you using a Lokar rod setup also?
Some guys complain that with a 4 speed the shifter is very low near there leg when in 1st?
Old 09-21-2016, 04:27 PM   #8
davepl
davepl's Avatar
No installed picture, sorry. Using the stock rod. I don't drive it in 1st much, so can't say, but I sure never noticed it being low. Seems fine to me in D.
Old 09-22-2016, 01:09 AM   #9
izzy_Britton
izzy_Britton's Avatar
what years of stock van tilt columns work best in the 67-72? mine is hammered and need a replacement. almost impossible to get it into park, the lock out mech on the engine side of the column is pretty worn and beat up.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 09-22-2016, 09:26 AM   #10
ls1nova71
ls1nova71's Avatar
About '74 up to '81..
Old 11-20-2016, 08:01 PM   #11
1965Impala
Are the van columns shorter than the stock 67-72 columns? It would sure be nice to get the steering wheel further from the driver.
1965Impala is offline   Reply With Quote
Old 11-21-2016, 06:58 PM   #12
68c10airstream
68c10airstream's Avatar
I would pay more and get a rebuilt factory from kev's classic or an ididit brand (made in michigan). Do some searching around and see the horrible chinese column internal images. Someone should be behind bars for bringing this crap to market! It's your life behind that steering wheel. Use the stock COLLAPSE-ABLE shaft in between the steering box and the column. Without it during a head on collision the steering box moves rearward and possibly the steering wheel pops up into your face. Gm also added features for the column to collapse within itself.
A drunk driver hit my mom head on in the 70's. She was driving a saab and the linkage collapsed and did it's job but the steering wheel was weak and folded forward and pinned my mom's hands to the side of the column including a 3 point seatbelt that i suspect didn't latch. She lived, neck injuries and all. She was short and close to the wheel and bruised ribs hitting the center part of the wheel (thats why i suspect the belt didn't latch).
When i see guys install aftermarket steering linkage between column to gearbox my first thought is " does it collapse like a gm one does"??? Enough of my rant but this one "hits home" for me every time!
68c10airstream is offline   Reply With Quote
Old 11-21-2016, 08:45 PM   #13
Cbo
I'd like to find this out too, before I pull the trigger on a tilt column
Cbo is offline   Reply With Quote
Old 11-21-2016, 09:27 PM   #14
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The van columns are actually longer. You can still move the column in toward the dash with a few mods. If I remember correctly, you have to cut a square hole in the column to allow the locating tab on the dash to go into the column. Then you will need to shorten your steering shaft due to the increased length. I have a van tilt in my 72.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
