What ALT to use ?
Hey guys, need some advice on what alternator to use.
This is going to go on a 402 Big block, with the wiring harness to run a internal regulated alternator. Need the pigtail to be at the 12 o clock position with the typical mountain brackets that attack to the head and adjuster uptop. Perfer if they have it at autozone ![]() Thanks! |
#2 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: What ALT to use ?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
AC-DELCO # 321-266
They're clockable, so you can loosen the four case bolts and rotate the pigtail to whatever position you'd like.
