Roof lights?
So yesterday as i was prepping to primer my dr. side door, i noticed on my roof there were these lil holes, and they were drilled, and had caulk in em, so i pulled the caulk off, and it appears to be roof lights, anyone know how the heck youd put em on if i got a set, or should i just silicone it shut and dont mind.
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks ![]() |
Re: Roof lights?
There are holes in your roof from screws and the hole to let the wire through, but no raised pods? You would need to get the same type as before to use the exact same holes. If you decide to reseal them, don't use silicone. Paint won't stick to that crap.
Re: Roof lights?
theres only one hole per thing, not a second.
![]() Join Date: Oct 2009
Re: Roof lights?
I'd look into the spacing and positioning of the existing holes - if you can buy a set of Yankee cab roof lights and use one of the existing holes per light and it works out, drill the 2nd hole and mount em up. Odds are the existing holes are not in the right place, in which case you could assess whether the RIGHT place would cover the existing hole with the Yankee light - that would be ok too, you'd just have to drill new holes for the Yankees in the right spots. Although factory fireman's hat cab lights technically could be mounted on a flush roof - they are really designed for mounting to a raised pad roof. Yankees are mentioned because they were designed to be added to a flush roof via aftermarket. Only way to fill existing holes correctly is to weld em up.
#5 | |
Re: Roof lights?
Re: Roof lights?
Honk!
These are the Yankee 77 style, I believe, and fit on the flat roof surface. They were the most common "back in the day". I never could figure out what the "official" spacing was so I kind of made it up myself based on what looked right to me at the time.
Re: Roof lights?
saved them pics on my phone, gunna use em for reference, when i do get the $$$ to buy some.
Go Pack Go!
Re: Roof lights?
Re: Roof lights?
Just a thought--could the roof holes be from a previously-installed visor?
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
Re: Roof lights?
What is the real purpose of "clearance lights" (cab lights/.roof lights) anyway? Big trucks have them, but what purpose do they REALLY serve?
I've never liked the reflection or glare they generated on the hood of the trucks I've driven, and if they are a clearance light, and they make the top of the truck taller, is it to REDUCE clearance, or know that you're close when you smash them on what's overhead? The only POSSIBLE thing I can think of is that of meeting a truck at night on a dark highway and his clearance lights can be seen before his headlights, so I know to dim my lights a millisecond before he has to dim his. Please enlighten me.
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
#11 | |
Re: Roof lights?
Thanks for the cig lighter CypressB.
1982 K10 SWB 1987 V20 - Sold - Doh! |
#12 | |
Re: Roof lights?
#13 | |
Re: Roof lights?
Also, see post 34 and 42 of this thread for Yankee 77 part # and price and 69-72 pad spacing. http://67-72chevytrucks.com/vboard/s...=451975&page=2 Last edited by jocko; 09-26-2016 at 08:32 PM. |
#14 |
![]() Join Date: May 2010
Re: Roof lights?
Clearance lights are required on vehicles over 80" wide by Federal and state laws. In addition to those on the roof, clearance lights also include the additional lights added to the sides and backs of vehicles over 80" wide. Take dually pickups for example. They always display the lights on the roof as well as a couple on the sides of the box (amber toward the front and red toward the rear) and some red ones across the back (generally under the tailgate these days). Remember the early 2000s GM pickups with 4 wheel steering? They were also over 80" wide and had a full complement of clearance lights.
I believe the quantity and spacing is also mandated. The lights may have been offered as an option on pickups under 80" for owners who bought the trucks for such things as snowplow duty (I think some plows are over 80"). When a truck is loaded with a cab-over camper, hood glow is present. It never bothers me though. As for the name, I've always assumed that they were called clearance lights since they aid other drivers by identifying vehicles that require extra clearance. EDIT: Some light reading. https://www.fmcsa.dot.gov/regulation...section/393.11 Last edited by FirstOwner69; 09-26-2016 at 09:03 PM. |
#15 |
Re: Roof lights?
I always wondered why people dont pull out in front of me so its my roof lights eh?I always thought it was the sign on my front bumper it says I HAVE DRUM BRAKES!!! The lights are cool I dont mind the hood glow
#16 |
BlahBlahBlah
Re: Roof lights?
This is an OEM instruction sheet for GMC dealer installed cab lights like the ones on davepl's truck.
Here is the link for this to see it larger and easier to read. You can open the pic larger than the one this link goes directly to. http://67-72chevytrucks.com/gallery/...pacing&cat=500
#17 | |
Re: Roof lights?
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks ![]() Last edited by Deer_hunter_088; 09-27-2016 at 09:54 AM. |
